Samsung Syncmaster 931BW - No Power
  • aliens
    • Nov 2011
    • 11
    #61
    Re: Samsung Syncmaster 931BW - No Power
    Originally posted by alexanna
    Those voltages are some common voltages we see.
    One thing to think about the flow chart you're looking at is for no power, you actually have power.
    The front power LED is not turning on and 0 volts on the Back light on pin indicates that the logic board is not asking for back lights to be on.
    One other simple test would be to verify that on/off pin on the front panel switch changes state as the power button is pushed. Usually this starts out as a high voltage and goes low when the power button is pushed.
    I can confirm that. The button is connected to 1.8V, which goes to 0V when I press the button (but pin 9 doesn't change from it's value of 0.141V, so it still doesn't seem to request back lights).
    • aliens
      • Nov 2011
      • 11
      #62
      Could the problem be one of the other caps I haven't replaced? They look ok but I guess that can still be misleading.
      • alexanna
        • Mar 2010
        • 1346
        #63
        If it's a cap it would have to be on the logic board.From what i can tell the power supply is working correctly.
        I don't know if this the correct name for it but,I would suspect a problem with the the user eprom on the logic board.
        Someone else will have to answer if it is serviceable or not.
        • aliens
          • Nov 2011
          • 11
          #64
          2 more thing I tried.
          1. I went to the troubleshooting no video step (analogical one) and skipped the tests required an oscilloscope to the step checking the voltage on CN400 (the connector that goes from the logic board to the LCD), and there was no 5V on pin 1,2 and 3. Following that I tested the PANEL_EN and BL_EN signal (they should High and Low for ON), and both of them were Low (the PANEL_EN one was 0.6V).
          I also tried testing the digital troubleshooting part, since it revers to the same 1,2,3 pins for 5V, but couldn't find the resistances they claim.
          2. The computer seems to recognize the monitor though. I don't have a second monitor to test, but I unplugged the signal cable while the monitor was plugged in, and I got that windows sound of disconnected device. When I plugged the signal cable back in the reconnected device sound played.
          Any suggestions where I can go from here?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • hill01
            Samsung UE75MU7009TXZG Endless Power Cycle
            by hill01
            Hi everyone and thanks in advance for any help I might get here
            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
            Since a few days, the TV won't turn...
            11-17-2021, 02:52 PM
          • Journey11
            Samsung TV won't turn on ... keeps cycling the power relay on & off
            by Journey11
            Hi All,
            First time posting here ... my name is Kevin but my friends call me Journey.
            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
            07-04-2024, 02:44 PM
