I need help fixing a Sony GDM-FW900 24” CRT
  • SpiderWaffle
    • Feb 2016
    • 13
    Re: I need help fixing a Sony GDM-FW900 24” CRT
    Hey thanks for reply!
    I was a bit skeptical this would be the only fix required given the funny green lines mentioned with the dynamic fuzzying. And wondering how long it would even last if it did remedy it.
    Alas it seems someone else grabbed it for $50, I hope they have good luck!
    • jhutchinson
      • Sep 2019
      Hey, I know I'm a bit late, but this thread seems to be immortal and my question doesn't feel worth a whole thread
      Is there anywhere left to source the fw900 flybacks? I've had one I've been troubleshooting for months, and people think the flyback is probably bad in my set. I don't believe the vacuum is compromised, because I can still get a picture to come on periodically, but never longer than a few seconds.
      This is one of the only places on the internet I could find anybody talking about sourcing and replacing the flyback, so idk if any of the wisebeards here have any insider knowledge I could use to bring this fw900 back into the land of the living. Cheers <3
      inb4 I'm YEETED for gravedigging xD
        • 31208
        bad flyback will usually make the set powercycle or make a ticking sound or a sqeal.
        i would be looking for cracked solder joints for intermittant stuff.
        • R_J
          • 9588
          If you are getting a picture, even for a few seconds, it is very unlikely to be the flyback. There are many protection circuits in these monitors that will shut it down if things are not correct, start by making sure the power supply voltages are correct.
          Then check that you have +B 220v, If this voltage is wrong the monitor will shut down, check C913 (33µf/450v)
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #45
            Agreed with the others - unlikely that the issue is a flyback.
            @ jhutchinson: remove the power supply (D) board and inspect for solder joints - especially things like the heater, and some of the linear rails attached to tall heatsinks (there are a few on there, and they don't have much support, so they do tend to crack the solder joints.) When I got my two GDM-FW900 monitors, one had a lot of bad solder joints on the power supply board. The other had only a few that didn't affect its operation. But it also had a bad (leaked) tube, as evident by the blue glow (arcing) coming from the back in the electron gun area. So what I did at first is put the "good" power supply (D) from the first monitor with the bad tube in the second with the "bad" PSU board. This got one of them working. Eventually I fixed the broken solder joints on the "bad" PSU board and that allowed me to get to testing the monitor with the bad tube... to only find out that one wasn't fixable.
            If bad comes to worse, I still do have the parts from that second "dead" FW900 monitor here (been keeping them as a spare for my other working FW900.) If you ever do swing by VA, you're welcome to try them on your monitor, though.
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Also, get yourself an HV probe and check the EHT to the CRT. It may be shutting itself down as the HV develops due to it being too high and tripping out the X-ray protection. If it's too high, you'll need to start checking the horizontal/HV section of the monitor. DANGER: Nasty voltages present there.
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
              • Lucian_Petrasescu
                • Nov 2021
                • Romania
                #47
                Hello Momaka!
                Do you still have any parts left from your FW-900s?
                I'm looking for the D-board, G-board and the NX-4504 FBT.
                • leowasta
                  • Nov 2022
                  • France
                  #48
                  I've a problem similar to your... I've a Dell p991 ( SONY CPD-G400 ) and sometime the image flick and when the image flick the spark gap SG901 sparks... Did you know a way to fix it??
                  Here a video of the probleme
                  https://files.catbox.moe/wljf3i.mp4
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #49
                    That is definitely not a FW900, it's a Dell P991 aka Dell P1130 aka IBM P275 which I'm intimately familiar with and I still have the P275 lying around at my grandparents' place. The P1130, my mom made me give it away a couple years ago lol.
                    So, open a new thread. It is likely your problem is either caused by dust, or by a FIRMWARE issue which can be solved via a special RS232 cable (USB to RS232 adapter works too) and the factory software which can adjust the G2 voltage. Also there is a temperature sensor on this chassis which causes more harm than good, I can guide you on how to disable it, I've figured it out myself many years ago from the schematics.
                    PS. If you have an old computer or laptop with a serial port, I can ship you the service cable with USB power plug for free just PM me your address once you get the required privileges. The P275 doesn't need firmware adjustments yet, I've had it for over 14 years and taken good care of it. It needs a full recap of the signal board as it's slightly wavy on the horizontal but that's a hardware thing and I use XP on that computer so I can't be bothered running any higher resolution than 1400x1050 anyway.
                    The P1130 I bought with the G2 issue, peak brightness with retrace lines visible at 0% menu brightness from day one of me owning it, and I built the cable and fixed it like 12 years ago.
                    A working TV? How boring!
