EM-190TFT problems
  • swampy
    • May 2011
    • 21
    EM-190TFT problems
    While im waiting on parts for my other project i thought id go back to this one .
    I changed all the caps a while a go but was still not getting it to go into standby it was just ticking on and off.
    So i changed the 1n5822 diode which fixed that problem
    But now its working for 5 to 10 mins and then going black from the top of the screen down and the only way to get it to reset is to unplug it and it works again.
    Has enyone got any ideas of whats causing this
  • swampy
    • May 2011
    • 21
    Re: EM-190TFT problems
    I still cant seem to have any joy with this one, im stumped
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • Hondaman
      USB problems?
      by Hondaman
      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
      08-12-2024, 03:26 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • clabr
      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
      by clabr
      Need help to solve some problems with this laptop.
      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
      Before this had happened I observed some other problems:
      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
      12-02-2021, 08:09 AM
