mag 2200w lcd wont power on
  • alick
    • May 2011
    • 31
    Re: mag 2200w lcd wont power on
    no he just looked at it and show it to another person and they both said i dont need the caps they are fine. the other guy from the tv store said the same thing about the caps. I think I should just get a mulitmeter and test everything myself that way i know what is good and what is not. I just dont wanna remove the caps if they are infact good still. they look almost new
    ps: he tested the fuse and they where both fine.
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      Well i am not knocking them but you cannot tell if a cap is any good or not just by looking they could be out of range in capacitence or out of range on ESR .
      You need an ESR meter to test them for ESR but they are expensive unless you do it for a living .
      With the heat you have had around the board they may well have dried out
      which again will cause them to fail.
      If you read through a few threads there are a lot of guys on here who have been doing it longer and have much more experience than i do who will tell you the same thing maybe one of them will look in and comment as i may have missed something .
      In my opinion for the sake of very little money that it will cost for new caps i would replace them anyway as they have been on the board from day one and are probably no good anymore .
      When caps fail they cause the voltages to go astray and hence cause problems like burning out other parts ie the mosfets .
      Sorry dont want to sound like i am giving you a lecture just trying to steer you the right way
      • alick
        • May 2011
        • 31
        no no don't be sorry, I don't mind, its all learning to me.
        I will go get the caps too and just replace em all so it eliminate the possibly of them being bad. i guess i should get a new solder iron and kit as well.
        thx
        I will updated you after i get the parts and give it a go. I have to wait until monday to order them from the parts store and wont get them until friday most likely
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Ok just make sure they are low esr
          • retiredcaps
            • Apr 2010
            • 9271
            Looking at caps without testing them and saying they are fine is like looking at a 9V battery that has been USED in a smoke detector for a 2 years and saying the 9V battery is fine for another 2 years.
            --- begin sig file ---
            --- end sig file ---
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Originally posted by sabre504
              If you have a multimeter you can test the transformers i have taken the following from Retiredcaps 2 seconds to black guide (might be worth reading the whole thing if you have not already done so
              Here is the "short cut" version. Measure the resistance between the 2 red dots. Report findings. Do the same for the yellow dots.
              • alick
                • May 2011
                • 31
                #27
                which of those multimeter will do the job? I have to pick on up tomorrow. also I trying to keep my budget under $45 if possible?
                http://www.leeselectronic.com/ will that one for $18 do it?
                • sabre504
                  • May 2010
                  • 449
                  • United Kingdom
                  #28
                  That will get you started
                  • alick
                    • May 2011
                    • 31
                    #29
                    Ok then my plan is set. Thx
                    • alick
                      • May 2011
                      • 31
                      #30
                      do you think this one will do??
                      http://www.mainelectronics.com/UT20B.html
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        If you can wait, Canadian Tire has this multimeter Product #52-0052-2
                        http://www.canadiantire.ca/AST/brows....jsp?locale=en
                        normally for 70% off (or $18 CDN on sale). They frequently have 70% off sales every 3 to 4 weeks.
                        I have used its earlier incarnation and it is decent for $20.
                        If more USA ebay sellers shipped multimeters to Canada, there is a lot of selection for good quality used multimeters (like Fluke, Amprobe, GreenLee, Meterman, UEI, Ideal) for $20.
                        I managed to find 2 Fluke multimeters locally (kijiji, craigslist) for $20 and $30.
                        In the end, it is your call. The Uni-T will work fine for basic measurements.
                        • sabre504
                          • May 2010
                          • 449
                          • United Kingdom
                          #32
                          Well its got the functions you need so will do
                          • alick
                            • May 2011
                            • 31
                            #33
                            Ok. Hmm maybe what I will do is get the cheap one now and get the other one once it goes on sale. Its good to know Canadian tire would have been the last place I would have looked
                            • smason
                              • 1652
                              Also Princess Auto has some cheap ones.
                              I use a cheap Princess Auto $12.00 powerfist special for general use at work (checking P.S. and wall wart output, continuity checks etc) and it does all I need.
                              • alick
                                • May 2011
                                • 31
                                #35
                                ok guys I got the mosfet in and while i was de-soldering them the first one came off without really any problem. the second one both leads broke off while i was attempting to use twizer and de-solder them. after placing them in and hooking everything up its still does that but now the picture come on for a second then off. I guess the next thing is to change the caps. I will need to see if i can find any cause the stores i went to had some but they are way to big. anyways i will keep posted!
                                • jetadm123
                                  • 2169
                                  #36
                                  Before replacing caps, I suggest you perform retiredcaps test on post #26 before you go any further.
                                  • alick
                                    • May 2011
                                    • 31
                                    #37
                                    ok so i measure those two the red and the yellow and they both are at 768 on the resistances. the metere was seT to 2000 was I doing it right? and is that reading ok or is there something wrong?
                                    • alick
                                      • May 2011
                                      • 31
                                      #38
                                      http://www.shopjimmy.com/mirage-860-...t-inverter.htm will this board here work as a replacement???
                                      or
                                      http://www.shopjimmy.com/860-ab0-190...t-inverter.htm
                                      • alick
                                        • May 2011
                                        • 31
                                        #39
                                        i found that transformers but i think I might just get the board instead. and maybe just use the old board for parts and to tinker with?
                                        http://cgi.ebay.com/2X-TRANSFORMER-7...091450#vi-desc
                                        • alick
                                          • May 2011
                                          • 31
                                          #40
                                          http://www.shopjimmy.com/860-ab0-190...t-inverter.htm this one is the right one??
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
