Recently my monitor became flickering coming out of standby. I do not often shut off my computer (including monitor) but did so a few times. The problem showed up during Bios/Post screen all the way to Windows Login. Obviously not a driver issue, to make a long story shorter. Having dual monitors, flickering and one not (reversed connections at GFX card same monitor flickered). Monitor also exhibits flicker when not plugged into any GFX card when powered on.
So I took it apart and have located some bad caps (surprise
), some bulging, and some leaking. Attached is a photo of the power board (front and back) as well as the Capacitors I would like to replace (whether they look bad or not). I would appreciate any advice on whether I should replace other parts that I have not listed. Thank you!
