Re: Dell 3008wfp faulty power supply
Something else to check for is rotting lvds cable
see here - last post
https://www.badcaps.net/forum/showth...008WFP&page=12
That's great advice Selldoor. I'm beginning to think this might be a different problem......
EDID corruption. I remember reading about this while doing some research on a Dell 3008 stuck in a color cycling mode.
Fabian. You can read the thread at Dell right here... http://en.community.dell.com/f/3529/t/19249766.aspx
Technical info on what EDID is here.. http://en.wikipedia.org/wiki/Extende...ification_data
And the only known software with instructions provided by Dell to fix this (since removed by Dell, but hosted here) http://darkshade.homeip.net/cgi-bin/...?m-1318862778/
*****Important****** Any time you are dealing with firmware, or flashing, there is a danger that something could go wrong and the EEPROM could be rendered totally useless. Since the Dell 3008 has 2 DVI ports. Check the other one to see if it works. You could always just use the VGA port. Or HDMI. In other words. ***use at your own risk***
Back from Christmas & family stuff, I'm going to read through all of this.
My experiences from the past:
1. The longer the monitor had been switched off completely, the longer it took to start up (screen remained black for half a minute).
2. The flickering (till now) occured only after hibernate mode (orange LED); which I hardly ever used.
This makes me think that the monitor may have been faulty for much longer than I previously thought. During years of normal use, I didn't perceive the slow start-up to be part of a failure mode.
Suppose a good signal is being sent to it, how long after pushing the power button does a properly functioning 3008WFP light up?Leave a comment:
*****Important****** Any time you are dealing with firmware, or flashing, there is a danger that something could go wrong and the EEPROM could be rendered totally useless. Since the Dell 3008 has 2 DVI ports. Check the other one to see if it works. You could always just use the VGA port. Or HDMI. In other words. ***use at your own risk***Leave a comment:
If the problem is due to bad caps the sooner you look at it the better or
leave it off until you can look at it.
When caps are failing they can cause collateral damage which can be difficult
and therefore more expensive to repair.Leave a comment:
This forum is *very* helpful!
I will certainly follow those nicely detailed & photographed steps; thanks for the links.
However the plot thickens. Yesterday the following went down:
1. I kept the monitor (while in failure mode) on for a while *without* any signal being sent to it.
2. All of a sudden, the screen pops up again! (blue screen: no signal)
3. Connecting the DVI cable with a signal on it makes it go back into failure mode (i.e. black).
4. *Disconnecting* that same cable makes the screen switch on again!
So after a while I thought: let's connect the thing with an analog cable.
5. It worked!
6. After a while I switched it back to DVI --> it worked! (including full-res)
7. Putting the computer to sleep --> display into hibernate (orange LED).
8. Switching computer back on --> Display starts flickering again!
9. Unplugging power cord & plugging back in --> no avail (still flickering)
10. Another computer sleep (orange LED) and back --> display works again.
I included 2 images: one of the screen in 'flicker' mode and one in normal mode.
Before I open it up I think I'll explore this failure mode a bit more. Particularly if the analog connection has had anything to do with it.
If I can get a workaround, I don't have to open it during Christmas
I'll update later. Thanks again.Leave a comment:
Yes. Time to open it up and check out the boards. You might get lucky and it will be some bad caps on the main board. I have seen that before on some earlier revisions.
As far as the proper way to open it up. I have a post https://www.badcaps.net/forum/showpo...&postcount=351
And this guy has a really good guide with pictures. http://forums.overclockers.co.uk/sho...php?t=18460501
We'll need nice sharp pictures. Mostly of the main board. You might even spot the bad caps. Sometimes they rupture out the bottom on that board.Leave a comment:
I tried once again, room completely darkened (accept for a blue LED..), to see something of an image (flashlight under various angles) when it is black. I didn't see anything.
When I switched on the monitor, it lit up properly (good image) for about 3 seconds this time. Repeatedly switching off and on again gives me a good image for about half a second after it turns black.
Windows properly recognizes the device (Dell 3008 WFP) during failure mode. When changing the desktop resolution I can see it scales properly (during the short time it's on) on the screen.
What's the best next step? Opening up the monitor and photograph the boards?
Thanks again!Leave a comment:
Hi Fabian. Excellent description of the symptoms.
First of all; if the D22 was out you wouldn't have the blue LED lit up. So that part is good.
It sounds like either a main board failure, or an inverter failure. It might be a bad ccfl, but that would be very rare. Try one last time with everything hooked up and a nice colorful image being sent to the monitor. See if you can detect any image at all in the dark. If you can't see anything with the flashlight at all; this is most likely main board.Leave a comment:
My name is Fabian, yet another unhappy owner of a faulty 3008 WFP. Mine showed somewhat peculiar behavior before failing altogether:
1. Over the past few months before total failure, the screen remained black for the first minute or so, after which it lighted up normally. The LED remained blue during this failure mode.
2. Just before total failure (the same day) the image flickered (mostly the bottom half). It didn't show distortion, just strong brightness fluctuations.
3. The total failure mode (today): screen pops up normally (no flickering) for half a second before it turns and remains completely black. Switching it off and on again repeats this phenomenon. LED remains blue.
When I check the screen in a dark room with a maglite I can't discern any activity; I don't think is (just) a backlight failure.
I am afraid this is some kind of firmware error rather than a power supply failure. My question:
Is it possible / likely that D22 or another 14V-psu component has failed? Should I open the monitor up?
Thank you very much for your time / assistance!Leave a comment:
There were none for just that board only 4 all together for 3008wfp
think 2 were for full sets and one for an inverter. I am just saying you will be very lucky to find one.Leave a comment:
Could you please paste me the links to the auctions? I cant find them.. :/ tyvmLeave a comment:
In normal circumstances that might depend on where you live.
Answers you might get would differ wildly from Germany Brazil
philipines Estonia USA Canada, However in this case I suspect no one knows have you found any for sale? I see only 4 items at all on ebay worldwide.Leave a comment:
whats a realistic price for the main board?Leave a comment:
Ok, Well the Genesis chip is on the Main board - the one with the video inputs on it.
If you can provide really clear picture of the board (Both sides) and close up of the labels someone may be able to suggest something or help you find a replacement.
First task may be to get inside - there are a few sets of instructions at the beginning of this thread.Leave a comment:
i asked two guys and got to different opionions, thats why..Leave a comment:
"I'm able to see the osd and the input source when I'm switching the sources so the display/backlights seems to work." I would think if the video processor is bad, you will not get any image or badly scrambled images.
So the backlights do stay on when the image disappear? I still do not understand about getting the new T-CON board if the GENESIS chip is on the main board.Leave a comment:
I'm able to see the osd and the input source when I'm switching the sources so the display/backlights seems to work.Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by Borse2008Hi everyone,
Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
