Dell 3008wfp faulty power supply
  • selldoor
    replied
    Re: Dell 3008wfp faulty power supply
    That is probably an ok D22 as the legs 1 and 3 are joined and the diode
    sections perform correctly.
  • vvulture
    replied
    Thanks for the reply selldoor.
    The "no reading" i was referring to is infact "OL".
    1-2 Resistance ( Reversed OL )
    1-3 SHORT
    2-3 Resistance ( Reversed OL )
    I can only set my DMM on ohms, 1kohms, 10kohms, 100kohms, 1Mohms, 10Mohms
    Cheers
  • selldoor
    replied
    There is no such thing as "no reading" unless your meter is not on or the battery is totally dead.
    Do you mean it is on 0.00 or perhaps a 1 on the right hand side of the screen
    or OL or something else.
    Try testing on ohms 200 test each leg to the other 1-2 1-3 2-3 looking for shorts (same as holding the probes together.
    Next Meter on ohms 2000 test 1-2 then again with the probes reversed
    then do the same for 2-3.and post the result
  • vvulture
    replied
    Hi Guys,
    Just removed D22 from my 3000wfp PSU.
    I am trying to determine if it is infact faulty but need some advice.
    Using a DMM in DIODE testing mode, i get a voltage drop of 0.158v when placing leads across Anode and Cathode.
    If i reverse the leads i get zero volts ( ie no reading ).
    Is this the correct way? and are the readings indicative of ok or faulty ?
    I need to know before purchasing a new diode which will cost me about AU$25 .
    Thank you
  • mozg1986
    replied
    And I draw now the scheme of the inverter, here part, responsible for DCR
  • selldoor
    replied
    Thanks for posting that- could be helpful in the future
  • mozg1986
    replied
    TMDS Cable the scheme, on the future
  • shrafciger
    replied
    No one can't help me?
  • selldoor
    replied
    Or PM werz 51 See further up )and ask if he has his 3008 apart does he have time to
    ohm out the pins on his connector.
  • selldoor
    replied
    I see now - you pinched his picture.
    I know its 2 years ago but you could try and PM kazkasneaiskaus and ask if he kept any record.
  • shrafciger
    replied
    I have replaced wire by wire, but forgot to twist wires. I think, this is only problem. However, I like to check if cable is properly wired.
  • selldoor
    replied
    That is one hell of job!!!
    I have only seen 3 cases of that - here is one
    https://www.badcaps.net/forum/showth...008WFP&page=12 start at post 240.
    I think you will just have to replace it wire by wire
  • shrafciger
    replied
    I need help to repair this cable:
    http://i61.tinypic.com/zwjn8y.jpg
    Could anyone explain me how to properly connect this 3 connectors A,B,C
    example: A1 - B6, A2 - B2 .... A24 - Cx
    and which of wires to TWIST?
    Thanks everyone who can help me!
  • werz51
    replied
    I find this thread 3 days after I replace my dead 3008WFP with a second hand 3011WFP.
    I'll order the part and try to fix my old monitor.
    Thanks to everyone for posting their how to repair this fault.
  • selldoor
    replied
    Well done! - hope it continues to work for you.
  • yzenezy
    replied
    It's working!
    Thank you everyone who has contributed here. I was able to debug it by reading through the thread again.
    At the top of page 12, Maxidud2000 had a similar issue to me in that the blue power indicator light came on but not signal was received and the on-screen-menu was not working. Selldoor's post in the thread suggests checking the fuses on the board at the top of the monitor. So I disassembled my monitor again and found that one of the plugs to that top board had worked loose during the first reassembly. I check the fuses anyway and found them good, reseated the plugs, reassembled and it worked first time.
    Thanks again everyone!
  • yzenezy
    replied
    Hi selldoor, I pulgged the connector in. Then I saw the backlight come on (at least I think it is a backlight as it is a kind of 'glowing' behind the LCD). On the same board there is a small dblue ribbon connector as well. I reseated that as well but still no output or on screen display (menu) showing.
    If I disconnect the VGA cable, the blue power indicator light turns to orange.
  • selldoor
    replied
    Did you see it working before or did you get it in to fix.
  • yzenezy
    replied
    Sorry, I forgot to connect the power board connector the the circuit board on the back-right of the monitor.
    Now I get a backlight at least but still no output. Also, the On-Screen-Menu doesn't show when I push the buttons. Not even the source select shows. I can't remember if this monitor has an auto source select.
  • yzenezy
    replied
    Hi Everyone,
    I have a 3008WFP in which I've replaced D22 with STPS40170CT (testing the old D22 showed it was shorted). I also didn't put the ferrite insulator back on the leg of the STPS40170CT. I hope that's OK.
    Anyway, I now get a blue power light and the monitor is detected by Windows 7 when I connect my laptop via the VGA connection, but the 3008WFP doesn't show any output. What do I do now?
    I haven't put the plastic case or bezel back on so disassembly should be straight forward. Any clues as what to do next are appreciated.
    Regards,
    Tom
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Borse2008
    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
    by Borse2008
    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
    • There’s
    07-15-2025, 04:55 AM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
