ViewSonic Optiquest Q191wb
  • Freezer
    • Jun 2010
    • 124
    I recently was given a broken ViewSonic flat panel monitor. Specifically a ViewSonic Optiquest Q191wb, model number VS11584. It's a 19" widescreen LCD monitor with CCFL backlighting. The reported problem was the monitor would not turn on.
    Step 1 was to open the monitor up. This ended up being more difficult than I had expected. Like so many monitors of this size it's held together by plastic tabs around the edge. But these tabs were very difficult to pop open. I ended up making a few minor scratches in the plastic as I pried it apart.
    Once open the monitor looks like every other monitor, the video board is on the right and the power/inverter board is on the left underneath some metal shielding. After I removed the shielding I immediately noticed a bulging capacitor. I ended up replacing the following 4 capacitors:
    C802 470uF/50V
    C817 1000uF/16V (obvious bulge on top)
    C819 680uF/16V
    C904 220uF/50V
    After acquiring the replacement caps I began the repair. I removed each capacitor, soldered in the replacement, and then tested the old capacitors using my multimeter. I know, I should probably test them first that way I don't replace good caps, but I figure caps are cheap and I'd rather not have to repair this monitor a second time. So I just went ahead and replaced all four. Unfortunately, my capacitor tester cannot handle electrolytic capacitors above about 500uF, so I could only test two of the capacitors. Here's what I found:
    Location | Rating | Measured Capacitance | Comments
    C802 | 470uF/50V | 433uF | Probably bad, 433 is only 92% the rated value
    C817 | 1000uF16V | na | Unable to test, but was bulging
    C819 | 680uF16V | na | Unable to test, probably was still good
    C904 | 220uF50V | 219 | Most likely still good
    I used the following replacement parts from Digikey (part numbers are Digikey part numbers):
    Panasonic EB series 470uF/50V - P13134-ND
    Panasonic EB series 1000uF/16V - P13119-ND
    Panasonic FR series 680uF/16V - P14395-ND
    Panasonic EB series 220uF/50V - P13131-ND
    Digikey is great. Parts were $2.86 plus a couple of bucks for standard USPS delivery. Parts arrived in 2 days.
    After soldering in the new caps the monitor works perfectly! So for less than $5 and about 5 minutes of actual work time I have a working widescreen monitor. Thanks to all the members on this forum. Everything I've learned reading other posts helped this repair to go smoothly.
    Hopefully this post will help others who might be experiencing problems with their Q191wb monitor.
  • dobber
    • Jul 2008
    • 83
    Re: ViewSonic Optiquest Q191wb
    Good Job, I have found that Viewsonics are one of my favorites to fix. Most of the time it is the cheap caps.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by Freezer
      I know, I should probably test them first that way I don't replace good caps, but I figure caps are cheap and I'd rather not have to repair this monitor a second time..
      You missed replacing C824. It plays an important role in the SMPS startup process.
      No multimeter I know of measures ESR (ohms). Low ESR caps are required in the SMPS application.
      --- begin sig file ---
      --- end sig file ---
      • Freezer
        • Jun 2010
        • 124
        Hmm, I intentionally left that one alone because in my admittedly limited experience small caps like this are never the problematic ones. But maybe I should just replace it to be thorough.
        I am seriously considering ordering the Blue ESR Meter kit. At which point I'll be able to truly test caps.
        • retiredcaps
          • Apr 2010
          • 9271
          That small startup cap has been responsible for many problems here on the board (including some first hand experience). It costs around 33 cents for a Panasonic FM or FC cap so it is a no brainer to replace.
          • Freezer
            • Jun 2010
            • 124
            I wanted to post a followup with more information. On retiredcaps suggestion I went ahead and replaced cap C824. I also recently built the Blue ESR kit, so I went back and tested all the caps I removed. Here's what I found:
            Location | Rating | Measured Capacitance | ESR | Comments
            C802 | 470uF/50V | 433uF | .04 | Low capacitance but ESR was fine, possibly dying
            C817 | 1000uF16V | na | 1.3 | High ESR, bad cap
            C819 | 680uF16V | na | .03
            C904 | 220uF50V | 219 | .06
            C824 | 10uF50V | 9.5 | 2.5
            Also, all the original caps were CapXon brand, known to cause lots of problems. Again, I hope this info helps someone else.
            • Rtech
              • Jul 2010
              • 1095
              For your C802,rember that the majority of electrolytic caps are plus or minus 20%,so in fact it would be within spec !!
              • retiredcaps
                • Apr 2010
                • 9271
                The Panasonic FC ESR is 1.3 ohms according to
                http://search.digikey.com/scripts/Dk...name=P10316-ND
                I think for the extra 33 cents and the fact that the Capxon caps are 5 years old, it was a good choice to replace the Capxon cap.
                • Freezer
                  • Jun 2010
                  • 124
                  I'm glad you mentioned this. I noticed on Digikey's site, very few caps have an ESR value, but they do have an impedance in ohms which is what you quoted. Are ESR and impedance the same, or at least for our needs can they be considered the same?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Basiclly yes.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      another little tip: look for the cap datasheets on google.
                      for example searching for "panasonic fc filetype:pdf"
                      ... and the first result is the FC datasheet
                      "filetype:pdf" tells google to only show pdf's and nothing else.
                      the only thing you need to watch out for is that the pdf should be from the manufacturer's website and not some random other site (because they might be outdated)
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Digikey also has the same datasheets linked on their site. That is, their links point to the Panasonic website.
                          by momaka
                          03-15-2023, 10:17 PM
                        • wattage
                          AOC AG493UCX 49-inch monitor - Firmware request
                          by wattage
                          Hello Badcaps Community,
                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                          07-13-2025, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
