dell E173Fpf burnt parts
  • picturevalve
    • Nov 2010
    • 13
    Re: dell E173Fpf burnt parts
    Hi, my board has none of the damage suffered by the op. Just C868 and R852. It looks like R852 will be 0.21 ohm as the dell 2209wa monitor has just such a resistor in the ht as a fusible 1W resistor. In my board R856 is a 5.1 ohm not 15 ohm. Second jpg shows side of heatsink where C868 committed capricide.
    • picturevalve
      • Nov 2010
      • 13
      Second image. I just wonder whether the "hot" side of the ceramic was touching the heatsink.
        Can I see the bottom side pf the board where C868 cap is to see how it is connected?
        Ceramic cap tends to fail as shorts circuit.
        • picturevalve
          • Nov 2010
          • 13
          C867 R852 and C868 form a pi filter on the ht supply so C868 is connected from R852 to ground. As C867 is 10nF 1kV, I suspect C868 is of the order of 22nF 1kV.
          • picturevalve
            • Nov 2010
            • 13
            The 2209WA monitor has a similar arrangement with a bead in the pi not the resistor.
            • picturevalve
              • Nov 2010
              • 13
              #26
              Replaced C867 and C868 with nice blue 10nF 1kV ceramics, the surviving C867 didn't look the part. Replaced R852 with a 0.22 ohm 1W fusible. All o/k.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                #27
                Hi, i have fixed one with same O.P. problem, lastly after 5 or more tries, 5 expensive mosfets dead and more, if you are interested on how email me..
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • padluke
                  Dell Inspiron 5570 and burnt parts
                  by padluke
                  Hello, I would like to ask if there is anyone here who could advise me if it makes sense to repair a motherboard damaged in this way. The damage occurred when the ntb was not turned off in the bag, where it got too hot. After cooling down, it wouldn't start. After removing the motherboard and connecting the adapter, the PQA01, PUI02 component burned, which is shown in the attached picture. PUA01 and PUV01 is very hot right now. Thanks a lot for any advice :-)
                  Padluke
                  03-03-2024, 08:54 AM
                • vidvansh
                  Dell Latitude 5500 EDC41 LA-G891P - Parts help
                  by vidvansh
                  I was trying to remove bios password from my dell latitude 5400 by removing and programming BIOS chip and i accidentally blown away 1 part above the BIOS chip which i think is a resistor. I looked at boardview of it and i came to a part R_0201.
                  Can anyone help me figure which part should i order to fix it or will there be any workaround to run the laptop.
                  I have attached the image of the part which i am missing....
                  06-10-2025, 06:24 AM
                • miccodan
                  Advice / Help with Dell Inspiron P59G001 with burnt chip (PU5101)
                  by miccodan
                  Hello All,
                  This is my first post here, I have worked in IT all my life however my knowledge when it comes to component level motherboard repair is extremely limited. That being said I have been attempting to learn more in this area. This laptop in question had liquid spilled on it a couple years back. No repair attempt was made at that time.
                  Upon plugging the laptop in and attempting to power it does not do anything besides show a white status light on the front that blinks on and off continuously. I then proceeded to remove the board from the laptop and inspected further....
                  12-05-2023, 09:09 PM
                • diamon
                  Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                  by diamon
                  I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                  Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                  Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                  Pictures of these boards:
                  Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                  Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                  Dell...
                  02-28-2024, 12:51 PM
