Gateway 19" Flash
  • el3ctroded
    • Nov 2008
    • 198
    Gateway 19" Flash
    No idea what the model number is, the back is lost for now. I didn't take it apart but wanna put it back together working
    Anyway, what I know: It generates 5V and 14.5V.
    The 14.5V should be 12V.
    It isn't the CCFLs, cause it won't work with 4 known good CCFLs
    It flashes on when plugged in, then goes off. The power led flashes at the same moment the screen flashes, but goes out. After going out, it does nothing, even when pressing the power button.
    None of the large caps are bad. Removed and tested them.
    Haven't tested the smaller caps.
    The secondaries on the transformers booth read 1.8k.
    No bad diodes or FETs.
  • el3ctroded
    • Nov 2008
    • 198
    Re: Gateway 19" Flash
    Oh yeah, and on the video board, U401 puts out 3.3V and U402 puts out 1.8V
    • jetadm123
      • 2169
      Try checking the two surface mount mosfets on the power board, U303 and U304 for shorts.
      • retiredcaps
        • Apr 2010
        • 9271
        Did you test both capacitance and ESR on the caps? They look like Samxon GF series. If correct, they don't have the greatest reputation with forum members here.
        I believe 14.5V DC is okay and will measure 12V DC once the backlight comes on and stays on (i.e. there is a load).
        --- begin sig file ---
        --- end sig file ---
        • el3ctroded
          • Nov 2008
          • 198
          U303 and 304 no shorts
          I did test the capacitance and ESR. They were fine.
          I checked the smaller caps, and esr doesn't check out. It's C109, next to the transformer with the HiPot Ok sticker (bottom right corner of transformer). Could that one be an issue? It's 33uF, 50V, and I don't have a 33uF at 50V. I have a 47uF 35v... Not sure if I could get by with that...
          Edit: well, measured again, its esr is only a little high
          • jetadm123
            • 2169
            The 33uf appears to be a cap for the startup circuit. Since you are getting the 5V and 14V outputs, that means the power supply portion is up and running and the caps are doing their job.
            If you connect the monitor to a working computer and point a flashlight at an angle towards the LCD screen, do you see a faint image of the desktop? If yes, then the inverter circuit could be at fault.
            • Rolin
              • Apr 2007
              • 174
              el3ctroded, I have a Gateway 19" with the same boards you posted - suspect it's the same monitor. I know this thread is old, but wondering if you ever found the problem. My 19" Gateway has a very similar problem - when plugged in the power LED quickly flashes then dead - power button does nothing.
              Did you ever fix this one or did you give up on it?
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Flashing power LED suggests either a short somewhere (trying to start, runs into short, shuts down, repeat) or a bad startup cap (tries to start up but fails). Maybe a bad SMPS controller IC, but if that one dies, it's usually completely dead.
                Do you hear any ticking noises coming from the PSU when the LED flashes?
                • Rolin
                  • Apr 2007
                  • 174
                  Thanks Scenic for your post. I have a thread already titled "Gateway FPD1950 NO POWER" https://www.badcaps.net/forum/showthread.php?t=19066
                  I think you're right, some sort of short on mine. When I plug in the monitor, the power LED quickly flashes (I probably shouldn't have said quickly flashes - it quickly flashed one time when the cord is plugged in), then dead - the button does nothing. This is probably a tough one to fix, and since el3ctroded never updated he probably gave up and moved on. Check out my thread and let me know if you have any ideas.
                  • ekozeko333
                    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                    by ekozeko333
                    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                    🔥 The Problem Started After Suspected ESD/PD Fault
                    I experienced a power issue or ESD event through a USB-C charger
                    After that, the NX20P5090 power switch was visibly burned and was replaced
                    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                    🧠 What I’ve Done So Far
                    Flashed...
                    06-21-2025, 02:48 AM
                  • corrize
                    Nikon D800 camera - flash don’t work and capacitor don’t charge
                    by corrize
                    Hello, I'm stuck in troubleshooting…
                    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                    10-01-2022, 10:02 AM
                  • abajor
                    Canon VIXIA HF S10 A read data from inernal flash memory.
                    by abajor
                    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                    I think my best shot is to figure out a way to read the internal flash memory outside...
                    07-20-2024, 12:04 AM
                  • Ihandyrepair
                    4 red flash led 65X950G boot Sony and android logo but then black
                    by Ihandyrepair
                    HI guys
                    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                    here is the issue
                    I have Sony and android logo. but then 4 led red flash lights front of the tv
                    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                    but then I get black screen and 4 red flash light at the front LED
                    but I get 3 led flash on the LED driver board.
                    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                    so I tried...
                    07-11-2024, 01:45 AM
                  • abhorsen
                    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                    by abhorsen
                    Hey guys,
                    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                    07-06-2023, 10:22 AM
