Help identifying replacement part
  • Welchs101
    • Sep 2008
    • 979
    I am working on a monitor VT17W7X and i need help identifying a replacement part and where to find datasheet.
    Can anyone help?
    I am enclosing a pic of the device.
  • POM_MJ
    • Aug 2009
    • 228
    Re: Help identifying replacement part
    I guess, it it AIC1117ACY (SOT-223) voltage adjustable version, used to supply 1.8V.
    and seem to working fine from voltage measured in your other thread.
    2) Markings: BS17P, Z74C4 (could not find datasheet on this one):
    Pin1: Measured 0.606V DC
    Pin2: Measured 1.87V DC
    Pin3: Measured 5.06V DC
    datasheet =>
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • alexanna
      • Mar 2010
      • 1346
      datasheet =>
      On my working monitor I was measuring 2.5 volts on the center pin on the bs17p regulator.
      I know I checked more than once. The only thing that was not hooked up was the LDVS cable to the LCD panel. I have another working logic board is there anything else I could check to help narrow down the problem.
      • alexanna
        • Mar 2010
        • 1346
        This data sheet shows a fixed version, and one is 2.5 volts
        http://www.datasheetarchive.com/Inde...A00426185.html
        • POM_MJ
          • Aug 2009
          • 228
          Yes, there're fixed versions and adjustable version to be used in different design.
          but for Welchs101 question and his thread, it's adjustable version I thought.
          • Welchs101
            • Sep 2008
            • 979
            how to know if its a fixed vs adjustable? I have no idea?
            • Scenic
              o.O
              • Sep 2007
              • 2642
              fixed ones usually have the output voltage in the model number... like "1117A-33CT" ... the -33 indicates 3.3V output voltage..
              same thing for -18 (1.8V) and -25 (2.5V)
              edit: in turn, some adjustable ones have a model number ending with -ADJ. Not all of them though..
              • POM_MJ
                • Aug 2009
                • 228
                in my opinion,
                for fixed output voltage version, pin1 is always 0V (ground), pin2 output the fixed voltage, pin3 input.
                for adjustable version, pin1 is not 0V (0.6xxV as your measured) because it's pin function to adjust output voltage.
                (see the datasheet for more information).
                • Welchs101
                  • Sep 2008
                  • 979
                  not sure what to order. I guess there is no way to find the datasheet for the actual part..........am i going to have to buy both and try them both out?
                  • Toasty
                    • Jul 2007
                    • 4171
                    You've been given the datasheet link, and now I've attached it here. Read it.
                    It IS the datasheet for the part. Read it. Page 2.
                    Absolutely correct.
                    Toast
                    veritas odium parit
                    • Welchs101
                      • Sep 2008
                      • 979
                      thanks. i guess i did not read carefully enough.
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • VoicE2000
                        usb-c hp elite x2 help me identifying this part
                        by VoicE2000
                        Hello all, Can anybody help me identifying this part its on the usb c line on a hp elite x2 ,Seem like a filter or cap ,or some sort of short or polarity protection.anyway its blown.
                        07-15-2024, 10:51 AM
                      • edugimeno
                        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                        by edugimeno
                        Hi There!
                        I'm trying to help my friend who owns a restaurant be just bought.
                        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                        It's stuck using, I guess, the 2 sided tape that comes with the strip
                        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                        09-05-2024, 09:34 AM
                      • G-Sting
                        iPad Pro A1876 SHORT Part Identify Help Needed
                        by G-Sting
                        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                        SO My main concern is what part should i order what should i search the name for ?
                        on Ipad...
                        05-15-2025, 09:30 AM
                      • Cvrado
                        Led TV Board Replacement, same part number and model, different size
                        by Cvrado
                        Hello my friends!
                        I have a question that I think you can answer and help me with!
                        I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                        So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                        My concern is that the board won't draw enough voltage to the bac...
                        03-02-2024, 05:05 PM
