Dell S199WFP Works for a few hours, then turns off
  • el3ctroded
    • Nov 2008
    • 198
    It's a widescreen. The backlight turns off after a while of working fine. When it turns off, it blinks a bit and then goes off.
    No obvious caps, and if it was caps, I would think it would stay on once warmed up, not turn off.
    Once it turns off, I can turn it on again, but it's on-time progressively gets shorted until it won't stay on any longer than a second.
    Seems to me to be a thermal issue, but nothing I can feel gets hot, and blowing on either side of the power supply pcb or the logic PCB does not seem to keep it on any longer once it gets to the 1sec to off mode. However if I let it sit off for a minute, it will stay on for longer.
    Thoughts?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Dell S199WFP Works for a few hours, then turns off
    Resolder the inverter transformers.
    A working TV? How boring!
    • el3ctroded
      • Nov 2008
      • 198
      Sorry, forgot to mention I already soldered the inverter transformers and the PWM IC and most of the stuff on the high voltage side of the inverter circuit, plus all the high-power components.
      • smason
        • 1652
        Does the monitor turn off, or just the backlights?
        • el3ctroded
          • Nov 2008
          • 198
          Screen is on, backlight goes out. I also just noticed that often the LCD gets brighter, like it surges, right before it turns off. Could that indicate an intermittent short in the transformer?
          I don't see any visible indicators of short in the transformer, but that could explain why it takes so long to short; the transformers don't get very hot, and there is a substantial amount of mass to warm up, but once warm it shorts.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Could be. But you'd need to monitor the 12v line that the transformers feed from to know for sure. If there's a sudden drop in that line before it shuts down then you may be correct.
            • retiredcaps
              • Apr 2010
              • 9271
              Post a clear focused picture of the inverter transformers (front and back) using manage attachments. Please don't post inline.
              --- begin sig file ---
              --- end sig file ---
              • el3ctroded
                • Nov 2008
                • 198
                Yes, the supply drops. Not a lot, but some. It's regularly at 16.4, and it drops to 16.3. That's the best I can tell using the DMM. After the backlight goes off, it jumps to 20v.
                I also noticed that one of the transformers is a little warmer than the other, and when it gets to 40deg c is when the whole thing shuts down...
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Just for fun, with power off and lcd unplugged, measure the resistance of secondary inverter transformer pins.
                  Measure the ohms between the 2 yellow dots. Report measurement. Do the same for 2 red dots. They should be within 3% of each other.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    You may have a problem with the supply feeding them. 16v to 20v is a big difference. What voltage are the caps on that rail and is it spec'd at some voltage anywhere? It's way too high to be a 12 volt. It could be a 18 volt rail... but the 16v reading is bugging me.
                    • el3ctroded
                      • Nov 2008
                      • 198
                      0.494 and 0.498
                      All the caps on that rail are 35V
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Close enough. Do measure them immediately after it's turned off too, but i don't think the transformers are the problem.
                        • Rtech
                          • Jul 2010
                          • 1095
                          Try some test CCFL's,instead of the originals,just to confirm that the fault is on the PSU/Inverter PCB.Funny things can happen with both lamps and lamp wiring,and it takes very little time to confirm.
                          • el3ctroded
                            • Nov 2008
                            • 198
                            coils were .500 and .503 after turned off.
                            Trying with different CCFLs.
                            The voltage rail that supplies the inverter circuit appears to be a switching boost regulator that is fed from a 12v rail. odd.
                            • jetadm123
                              • 2169
                              If swapping CCFL's doesn't resolve the problem, try acclerating the shutdown process by heating up parts of the power board using a hair dryer. I would concentrate around the CCFL controller area, inverter transformers and the two 8-pin mosfet chips between the transformers.
                              It also could be a bad solder joint. Try gently pushing down on various parts of the board with a wooden dowel or some other insulated object.
                              Also, a photo of the entire power/inverter board would be helpful.
                              • el3ctroded
                                • Nov 2008
                                • 198
                                It looks like the ccfls did the trick, but I could only run it for 2 hrs before I had to leave. Will test more tomorrow.
                                Thx for the hair dryer tip and dowel suggestions, will try if diff. ccfls don't last for a long haul...
                                • el3ctroded
                                  • Nov 2008
                                  • 198
                                  Got the screen apart and one of the return wires on one of the CCFLs was broken off. Soldering it back on and I'll soon see how it works.
                                  • Kambi13
                                    Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                                    by Kambi13
                                    Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                                    Not heat related, everything is ok regarding to that.
                                    All voltages are present.
                                    Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                                    Motherboard is Cedar 13269-1 F3XMC Rev A00...
                                    07-12-2024, 06:10 AM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • TheQuentincc
                                    Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                                    by TheQuentincc
                                    I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                                    06-26-2025, 01:44 PM
                                  • manol278
                                    Dell laptop E6440 val91 la-9934p turns off
                                    by manol278
                                    Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
                                    I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
                                    If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
                                    I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
                                    [Mod. Edit]
                                    Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
                                    01-26-2024, 11:50 AM
                                  • CapLeaker
                                    Dell ATX PSU won’t start, but forcing it works fine?
                                    by CapLeaker
                                    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                    10-28-2024, 06:59 PM
