Sony SDM-HS73 Turns on for a few seconds then black screen
  • Welchs101
    • Sep 2008
    • 979
    Re: Sony SDM-HS73 Turns on for a few seconds then black screen
    yeah.....my feelings exactly. In trying to locate a "like" monitor that i could use as a bulb tester i found that if i plugged in the video cable monitor would not shut off...........really sorry. But i do thank you guys for your help!!!!!!!!!
    • alexanna
      • Mar 2010
      • 1346
      Don’t feel too bad,
      I Use a free screen tester, from one of the major camera manufactures, It starts with an N.
      Well I unplugged a monitor when the program was in a white screen test mode. I almost condemned another LCD as having a white screen problem. The only thing that saved me was noticing the mouse pointer on the screen.
      Al.
      Last edited by alexanna; 01-19-2011, 09:43 AM. Reason: well not sure if they do cameras but it's a neat program
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • Yosua
        sony vaio MBX-237 every 35 seconds it turns off again
        by Yosua
        hi friends, I want to share about my problem with the mobo SONY VAIO MBX-237, the case is when pressing the power button it turns on (without display) but in 35 seconds it turns off again, I have measured the resistance on all coils, and the result is 1 coil near the vga chip there is no voltage when the mobo is on, and my problem is because on this mobo there is no code for each component, I hope someone can help me here, thank you....
        03-27-2022, 08:14 PM
      • Rav_tangle
        MacBook Pro 2011 turns on with keyboard light , screen dead
        by Rav_tangle
        Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
        I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
        Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
        is this...
        05-31-2024, 04:09 PM
