I know that the length and diameter need to be correct. Dose a ccfl have a voltage ratting? Does it matter which end is wired to the output or return lines? Are there other things to consider when finding a replacement lamp?
What data is required to identify a CCFL lamp?
Re: What data is required to identify a CCFL lamp?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Happened to me once (i saw it from a monitor repaired by someone else).Since there was a set of 2 new ccfls, the guy installed one new on top and one new on the bottom.Screen was colored evenly after that (yet, the colors were different a little bit than with the original lamps)There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job)
The only way to tell the color temperature of the original CCFL is to power a functioning one up on an external inverter.
I know I can identify a 3000K, 4100K, 5000K, and 7000K beyond that visually I'd be stumped.
5000K is a neutral white color 7000K is still white but with a bluish tint and the further you go up in kelvin the bluer the light gets.Elements of the past and the future combining to make something not quite as good as either.Comment
by mikey5791Hi,
This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...-
by jovani1989Help required to identify ic circled with red in atached, from a Asus M1403QA R2.0 motherboard. No schemathic or boardview available. Seems to be a power suply ic. Thank you!...
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by thesameHy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
by silver60618Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
Any help would be appreciated... - Loading...
