VX 724 black screen green light flashing
  • Jorge.ar
    replied
    Re: VX 724 black screen green light flashing
    Originally posted by budm
    the cap will be on the VDD pin not at Vin pin. See the spec sheet of the IC and how it works, But at this pint the IC is probably damaged by now.
    OK, found it, and also replaced before killing the SMPS ic.
  • selldoor
    replied
    Originally posted by Jorge.ar
    here a pic of the damaged part.. I think is R628
    Id suggest R327 as a description R325 doesnt look too happy either
    By the way where is this part CET541 - doesnt get a mention in the rest of the thread and doesnt google??
    replied
    the cap will be on the VDD pin not at Vin pin. See the spec sheet of the IC and how it works, But at this point the IC is probably damaged by now.
  • Jorge.ar
    replied
    What do you have on VDD pin, it can be that the startup cap on the VDD pin is bad.
    From spec sheet, the Vdd must reach 16VDC for it to atsrt up:
    The turn-on and turn-off threshold of SG6841 are
    fixed internally at 16V/10V. During start-up, the hold-up
    capacitor must be charged to 16V through the start-up
    resistor so that SG6841 will be enabled. The hold-up
    capacitor will continue to supply VDD before the energy
    can be delivered from auxiliary winding of the main
    transformer. VDD must not drop below 10V during this
    start-up process. This UVLO hysteresis window insures
    that hold-up capacitor is adequate to supply VDD during
    start-up.
    I didn't find any capacitor in the startup circuit.. From +V of the main capacitor, there is four 390K resistors in series then to VIN.. and no cap to gnd.
    Maybe the SMPS IC was damaged before the blown..
  • Jorge.ar
    replied
    IRF540 has Vds of 100V, your power supply if it is 230Vac, it will be exposed to about 330VDC. You may have also damaged the SMPS IC due to blown Gate drive network parts as shown in your picture.
    Damn,.. so CET541 (original mosfet) is not IRF 541...
    replied
  • Jorge.ar
    replied
  • Jorge.ar
    replied
    Thanks to both of you
    Bad news.. I replaced the mosfet (CER 541) with a IRF 540 and somethin exploded...
    I remember that the SG6841 VIN pin was something like 3.2V.... I will try to fix the board and try again.
    replied
    lol - simultanious post
    replied
    if sg6841 has a small startup cap then replace it.
    replied
    start-up.
  • Jorge.ar
    replied
    Hello!! Its been 4 years since last post in this thread...
    Yesterday my VX724 died. Started with the power led blinking, and then died. After disassembling I noticed that the main cap had some fluid leakage.. changed the main cap, the 220uF caps and the 330uF caps. The others seems OK.
    The main cap is charged but there is no 12v at the output. I disconnected the PSU and disconnected the inverter (opened the jumper 9 that connects +v from 220 caps to +v of 330uf cap)
    I checked VIN of SG6841 and it's ok, but there is no PWM output and no signal in the gate of the mosfet (checked with oscilloscope, GND = negative of the main cap)
    I don't know what else to check.. I will desolder the mosfet and check it.
    Thanks!!!
  • Nocta
    replied
    Sorry for bumping this thread but I just wanted to update it.
    I fixed it. It was the ribbon cable just like you mentioned once.
    Best part is that I learnt my lesson. I was given a Viewsonic display with same symptoms (red lines, bad colour) and now it's fixed too
    Thanks for your help and patience!
  • Nocta
    replied
    I won't give up with this monitor.
    I've been looking closely at the diagram and you were right, some caps were 10uFx16. Exactly 8 caps (of 12). LOL.
    Image is now even worse than it was before. Now I have some red and green vertical lines on the display. I checked again the VR and output voltage is 4v (which should be 3.3).
    Should I order a couple of AMS1117-3.3 instead of AS1117-3.3 (the ones I used to replace the original VRs)?
    Thanks.
  • Nocta
    replied
    DMM 2k Ohm
    U1:
    SMD 331: .325
    SMD 308: .146
    U3:
    SMD 308: .197
    SMD 308: .146
    I can't read the numbers of the resistors but that's what I think it's written. I used a magnifying glass.
    Thanks again and sorry for the delay. I've been a bit busy.
  • Jasgriff
    replied
    Strange that they are different from the diagram.
    Can you measure the resistors that are in series with the ADJ pin and tell us your findings.
  • Nocta
    replied
    The originals were TEAPO 22uF 25v. I still got them here.
  • Jasgriff
    replied
    Acording to the diagram those caps should be 10uf not 22uf what were the values of the ones you took out? I'm reading this on my phone so I apologize if I'm wrong.
    replied
    "U1
    Pin 3 (gnd): 4.96v
    Pin 2 (tab): 3.94v
    Pin 1 (Vin): 2.70v
    U3
    Pin 3 (gnd): 4.96v
    Pin 2 (tab): 3.94v
    Pin 1 (Vin): 2.25v"
    Since the voltage regulators (xxx1117 series) have 1.25V ref built into the design of the regulator (fixed 1.25 between output pin and the Adj pin). You can tell buy what the output voltage will be by adding 1.25V to the Adjustable pin (pin1) then you will know what the out put will be. In your case, the output is correct to what you will get on U1.
    U1 pin 1 is 2.70, so add 1.25 to it, then you will have 3.95V. But on U3, there is something not right with U3 setup.
    So in this case, it is either the Adjutable pin network resistors are off in values or the voltages as hsown in the diagram is not applied to your monitor.
  • Nocta
    replied
    Originally posted by retiredcaps
    Hmm, those still look incorrect to me, but trying test the new regulators to see if they are shorted or not.
    I'm testing the new regulators.
    Originally posted by Jasgriff
    Hi Nocta,
    Just a few bits...
    To give you an idea of what the regulars are finding confusing I will show you what you are getting on 2 of the regulators compared with what you should be betting....
    U1
    Pin 1 (left): 4.96v Should be ( 5V so this is close enough )
    Pin 2: 3.94v Should be ( 3V 25% out of spec )
    Pin 3: 2.70v
    U3
    Pin 1: 4.96v Should be ( 5V so this is close enough )
    Pin 2: 3.94v Should be ( 2.5v This is massively out )
    Pin 3: 2.25v
    Something is very strange about the fact that both of the output readings that you have given are exactly the same.
    I have attached a diagram which shows you where each pin number is. Can you look at this diagram and use that as a reference when giving us readings from pin numbers as i'm sure they are the wrong way around.
    I know you have said that you have replaced some caps and you removed some caps to get to the Voltage regulators. Can you you confirm if you have changed the following? if so can you tell us what you replaced them with? EC1, EC2, EC3, EC4, EC5 and EC6
    Can you also check that EC5 is definitely in the the correct way around and all of the others too please. ( Its hard to tell from the pictures but it looks like I get can see more white under that EC5 cap on the + side of it ).
    I fully recapped the logicboard so from EC1 to EC6 are all new. EC4 330uF 16v; the rest are 22uF 25v (I did not find 22uF 16v).
    What I wrote is the other way around. I numbered them from left to right and the tab pointing at me. So, now, following your diagram pin 1 is pin 3 and pin 3 is pin 1.
    U1
    Pin 3 (gnd): 4.96v
    Pin 2 (tab): 3.94v
    Pin 1 (Vin): 2.70v
    U3
    Pin 3 (gnd): 4.96v
    Pin 2 (tab): 3.94v
    Pin 1 (Vin): 2.25v
    I really appreciate your input. Thanks.
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • jimjoe123
    LCD TV Green/Pink screen problem
    by jimjoe123
    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
    Then each time...
    02-23-2020, 01:29 AM
  • kokos
    LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
    by kokos
    Hi ! to all fellows out there!
    I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
    I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
    The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
    I tried connected the lan and I can seee TV via local lan (as a device I...
    02-26-2024, 10:48 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:33 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    01-26-2025, 08:18 AM
