Reflecting on a cap-swap...
  • Madcat
    • 24
    Greetings folks, new member here!
    I have in my daily usage an Acer AL1916 lcd for 5 years already. About 3 years ago, the screen would take 2 hours (no joke) to power up. I crack it open and I smell "maple syrup". I learned from that day a "maple syrup-y" odor is the sign of blown lytics. I was right. All the caps on the lcd's psu were blown. I swapped them for some polymers off Digi-Key. LCD's been strong 3 years.
    An associate of mine has a bad LCD which refuses to power up. It's been sitting in his home office for about 3 years. I never got around to messing with it until a week ago. I laughed a little when I saw the brands of the lytics on his lcd's psu.
    CapXon and Taicon.......godamnit....lol
    Same two brands I had to put up with in my Acer! I laughed yet again when I found them on badcap's s---list. I'm wondering now if I was too hasty in buying polymer caps instead of good lytics. I didn't realise at the time all the homework one can do when choosing caps. Back then I just got out of my electronics course so I was still green?
    I need some food for thought. What do you folks think?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Reflecting on a cap-swap...
    Since it's been working for 3 years with the polymers i don't think you can say you did a bad job. I'm a more practical guy - since i have caps from all over the place i can't get datasheets for all of them. If it does the job, i use it.
    A working TV? How boring!
    • romansroad
      • 123
      I'm a more practical guy - If it does the job, i use it.
      I agree. I'm a bit surprised you could find polymers in the right values, but that's great.
      • Madcat
        • 24
        I guess I didn't screw up so badly eh? After reading about all the computer psus and capacitor details I guess I'm good. From what I gathered the psu in the lcd doesnt have wildly changing loads like a psu for a pc would.
        As for the values of the caps....I think (keyword: think) all of them were available on Digi-Key. There wasnt any cap so far out of volt/cap range. My Corsair PSU is another story.
        • ronaldopdias
          14" MacBook LCDs - has Apple re-introduced a new serialisation type?
          by ronaldopdias
          Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
          • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
          • Transplant the IC onto another screen:
            • If the model and revision match exactly then it will perform as normal
            • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
          06-28-2025, 09:56 AM
          by momaka
          03-12-2025, 03:42 PM
        • Uranium-235
          Customer with SS AMP not used in years
          by Uranium-235
          He has a pioneer SA 608, matching Tuner (TS 608) and Tape deck (CT F600) and a pointless timer (DT 400)...late 70's early 80's from my research
          We're going to try to focus this as a Turntable setup (his turntable is a seemingly cheapo from like 10 years ago...but it does have a phono out), which is at least comforting because the amp has a phono input. It also had a USB port, looks pretty cheap
          I'm trying to go for an all analog here. What is the likely problematic caps? Power? I've never dealt with amps this old and of this type. I replaced them in a cheap yamaha...
          10-07-2021, 07:55 PM
        • spwoof
          Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
          by spwoof
          I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
          If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
          10-05-2024, 08:02 AM
        • spwoof
          by spwoof
          10-05-2024, 07:24 AM
