Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
  • spwoof
    • Oct 2019
    • 6
    • Brazil
    I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
    If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook repair business for 20 years, but MacBook LCDs are new territory for me, and I'm eager to learn.
    Thanks in advance for any assistance!
    Attached boardview and schematic. Not sure if they cover LCD but worth looking through (search doesn't work well within the PDF)
    • spwoof
      • Oct 2019
      • 6
      • Brazil
      Hello. Thank you very much.
      But unfortunately the TCON and all the electronics of the LCD are on the LCD itself, and I couldn't find anything on the board's schematic.
      I wouldn't like to have to change the entire LCD because of a resistor or even due to a TCON failure.
      If it's possible to just change this electronic to solve the black screen problem, I'd like to know what to do.
      • 1centchips
        • Feb 2016
        • 41
        Can you source/ buy a broken lcd assembly with working backlight and broken lcd? That would be your best option.
        • 1centchips
          • Feb 2016
          • 41
          Or you can post a picture of the tcon board with the diode measurements? If I can make time I can do that for you but no promises. :/
          • Henry Law
            • May 2025
            Did you ever find a way to tear it down or did you just replace the screen outright?
            • spwoof
              by spwoof
              If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
              10-05-2024, 08:02 AM
            • rcanpolat
              M1 MacBook Pro 2021 A2485 - No backlight display
              by rcanpolat
              I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
              Here’s what I’ve observed so far:
              • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
              • I did some basic resistor
              08-24-2025, 02:16 PM
            • Loki_Fido
              Requesting help identifying chip in Macbook Pro A2485
              by Loki_Fido
              Hi ya folks,
              I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
              It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
              I replaced it and the SSD are fine. No more shorts.
              But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
              But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
              Chip marking...
              08-07-2025, 10:17 PM
            • PITERPENY
              Macbook Pro A2485 820-02100 SSD
              by PITERPENY
              Hello. SSD UN0000/0100/0200/0300 were shorted in the MacBook. There are 4 SSD chips on the board. I don’t have the same board and I removed two SSD UN0000/0100 chips from the MacBook on the M1 A2338. I installed only these two, but the machine does not recover and gives error 28. I have a question: is it necessary to have all 4 or should it work with two chips? Is this important for the M1 Max processor?...
              05-11-2025, 06:30 AM
            • awe126
              Macbook Pro 16" A2485, 820-02100, battery service recommended, fan full speed, doens't charge
              by awe126
              Hello all,
              I bought a Macbook Pro 16" M1 Pro, A2485, 820-02100, which working flawlessly but not charging. I thought battery needs to be replaced but then started reading and it seems that problem will be in motherboard.
              Battery sign has cross sign and MacOS can't read battery stats. Fans are full speed but can be set down via Fancontrol software.
              I did start digging into in and found out below:
              Diode mode:
              SMBUS_BATT_SCL: 0.529
              SMBUS_BATT_SDA: 0
              SMBUS_BATT_SCL: 1.795V
              SMBUS_BATT_SDA: 0.948V
              Can anyone help...
              03-27-2025, 12:23 PM
