Dell E172FPt repair. White lines on screen.
  • Welchs101
    • Sep 2008
    • 979
    I am enclosing a picture of what the problem is......i dont think i can describe it in words adequately. Basically, when i power up the monitor.....the LED comes on and "white" lines show up on the screen.
    I did measure the voltages at the connector with the LED on and off.
    Power to monitor and LED off: Gnd lead set to "neg" of big 100uF cap.
    Black: 81.1V
    Brown: 81.1V
    Red: 0.03V
    Orange: 0.03V
    Yellow: 81.1V
    Green: 81.1V
    Blue: 86.1V
    Purple: 86.1V
    Grey: 81.1V
    White: 81.1V
    Power to monitor and LED ON: Gnd lead set to "neg" of big 100uF cap.
    Black: 80V
    Brown: 82.6V
    Red: 0.004V
    Orange: 0.004V
    Yellow: 79.4V
    Green: 79.4V
    Blue: 84.4V
    Purple: 84.4V
    Grey: 79.6V
    White: 79.6V
    Any ideas on if this is fixable or not? If so what to try to identify the problem.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E172FPt repair. White lines on screen.
    Black: 81.1V
    Brown: 81.1V
    Red: 0.03V
    Orange: 0.03V
    Yellow: 81.1V
    Green: 81.1V
    Blue: 86.1V
    Purple: 86.1V
    Grey: 81.1V
    White: 81.1V
    Black: 80V
    Brown: 82.6V
    Red: 0.004V
    Orange: 0.004V
    Yellow: 79.4V
    Green: 79.4V
    Blue: 84.4V
    Purple: 84.4V
    Grey: 79.6V
    White: 79.6V
    I'd say a bad panel board.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      when you say panel board ......... do you mean the "logic" board....ie...not the power supply or the inverter board.
      • alexanna
        • Mar 2010
        • 1346
        Try cleaning/Reseating the ribbon cable from the Logic board to the LCD panel,Both ends.
        Al
        • retiredcaps
          • Apr 2010
          • 9271
          Black: 81.1V
          Brown: 81.1V
          Red: 0.03V
          Orange: 0.03V
          Yellow: 81.1V
          Green: 81.1V
          Blue: 86.1V
          Purple: 86.1V
          Grey: 81.1V
          White: 81.1V
          This won't help with your panel problem, but when measuring the connector, like above, I usually use a ground screw closest to the connector. This gives me more "normal" readings like 5V DC, etc versus 86.1V.
          On most connectors, you will see them labeled 5V, GND, BL/ON, etc. I can't tell your board due to the angle though.
          --- begin sig file ---
          --- end sig file ---
          • PlainBill
            • Feb 2009
            • 7034
            No, the board under the metal cover at the top of the panel. A cable runs from the logic board to the panel board.
            PlainBill
            • Welchs101
              • Sep 2008
              • 979
              Thanks all for the suggestions / info.
              I took a look at the "panel" and i could not see anything "obvious" so i am including a few pics of it. If anyone has any ideas please let me know.
              • bonney
                • Oct 2008
                • 74
                Get a pencil with a rubber top and run the pencil along each tab and see if you can find a tab at fault
                • thstuff
                  SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                  by thstuff
                  This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                  Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                  1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                  2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                  01-30-2023, 05:01 PM
                • EazyBone
                  75r648 TCL 8K Mini LED White Horizontal Lines
                  by EazyBone
                  TV turns on, lights work sound works.
                  TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
                  First experience with 8k and mini LED. Does this picture tell you anything?
                  Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
                  Any tip or trick on where to start would be appreciated.
                  Going to research the lines. Also going to disconnect...
                  11-14-2023, 06:42 PM
                • brad2157
                  Vizio E70-E3 Two white vertical lines
                  by brad2157
                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                  Replacement main board - Boots up fine, but starting...
                  12-13-2021, 05:11 PM
                • zoontz
                  SHARP LC-70UD27U black and white lines
                  by zoontz
                  Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                  What I have tried so far.
                  I have tested all HDMI inputs with the same results.
                  I have checked for firmware updates.
                  I have reset to factory settings.
                  I have removed...
                  07-09-2024, 05:50 PM
                  MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                  This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-06-2024, 07:46 AM
