Hanns-G HG281D, LCD Monitor no power
    Re: Hanns-G HG281D, LCD Monitor no power
    OK. I've just found 3 dry caps (C603,606 and 707). Going to buy repair kit and replace all of them. Thanks to every body for your support.
      Make sure your kit includes ALL the caps. I've seen some kits that leave out the small caps.
        Thanks for your advice.
          Let us know if new caps solve the problem or not.
          --- begin sig file ---
          --- end sig file ---
            I will. Thanks for your help.
              Just repaired my Hanns-G HG281D, LCD Monitor. Replacing 3 dry caps (C603,606 and 707 & couple more small one) returned monitor back to normal life. Thanks to every one for help and support. Best regards.
                Good work. Saving a 28 inch monitor from the landfill is a good feeling.
                  I have a problem with this monitor where it takes about 50 tries to get it to turn on. Once it is on everything works perfectly. Is there a good way to test the power supply board? I would like to plug in the AC power and turn on the board without using the monitor's power button. I see that in the back there's a printout that says PSON so I wonder if I can use that some how to turn the board on. Let me know of any suggestion. Thanks.
                    Did you check the switch?
                    Mann-Made Global Warming.
                    - Dr Seuss
                      Perhaps a little more detail would help. Do you have to hit the power button on the monitor repeatedly to get it to turn on, or does the problem occur when you apply AC power?
                      The power supply in this monitor is a dual design - the standby section of the monitor is always on and takes only a few watts (possibly less than 1 watt). The main section is switched on only when it is active and draws most of the power.
                      The symptoms you describe sound like bad capacitors, and the layout of the power supply looks like it was designed to kill caps!!
                      PlainBill
                        Please post some photos (top and bottom) of the power board per PlainBill's links in Post #30.
                          Yes the switch has been physically checked. It seems to open and close just fine using an ohm meter. According to this post, it seems that the problem is most likely due to the power supply board. If I unplug the AC cord and replug it into the wall, it seems like it has a better chance of turning on than me just repeatedly hitting the power switch. I will take some photos once I am home from work.
                            PlainBill
                            The monitor can sometime turn itself on right when I plug in the AC power. Then sometimes it can turn on when I try to press the power button repeatedly. Once I can turn it on, I can turn it off and on for about 5 times consecutively before it stops responding.
                              My initial guess is the startup capacitor is acting up. It's under that metal cover. Can you remove it and retake the photo?
                                Like the OP, all his caps looked good (no bloating), but after testing with an ESR meter, he found 3 dry caps and proceeded to switch them all out and save a 28 inch monitor.
                                If you have a multimeter, see if you get stable 5V STB DC (details in previous posts).
                                  As is common for larger monitors, there is a PFC front end on this power supply. MORE complication. I would agree with retiredcaps. Do replace all electrolytics, especially the tiny ones.
                                  PlainBill
                                    I think I will try to check the caps first with the ESR meter since I have to desolder this cap in order to remove that metal cover. I dont have a soldering iron with me atm.
                                      Hi there,
                                      Just to add my 2 cents, I had a dead Hanns-G HG281D too, and after following the advice and info here I managed to get this dead monitor working again.
                                      There were 3 dry caps that were measuring low/incorrect capacitance once removed from the power supply, which were C603,606 and 707 also found by Mishannya. (these caps did not look puffy or leak either on inspection)
                                      Many thanks to this great site!
                                        I'm in the process of recapping the power board on my HG281D as well. Ordered the caps from Digi-key, on their way now.
                                        Mine turns on for a while (15 mins or so) then shuts off. I can turn it on again and same thing happens except it shuts off within ~10-20 secs.
                                        My power board looks different than yours and has a manufactured date of May 2009. Here is a pic with cap values:
                                          Your monitor is under 2 years old. Isn't it still under warranty? It would be suprising if the cap(s) failed that quickly.
