Dell W1700 LCD Rev00
    Re: Dell W1700 LCD Rev00
    I attend answers and comments
    a regard to everybody of the forum
    mario
      salve
      Sono sempre io Mario dall'Italy
      Ho montato l'inverter ambit sul monitor w1700 e il tutto funziona però è rimasto il primo difetto che avevo all'orrigine cioè una riga che divide in due lo schermo del monitor, vi invio la foto che evidenzia il difetto
      Prego qualcuno di risolvere questo problema.
      grazie a tutti gli amici del Forum
      http://www.flickr.com/photos/19922995@N07/2239821154/
        hi
        I am always me Mario from the Italy
        I have climbed on the inverter ambit on the monitor w1700 and the everything it works however the first defect that I had that is to the orrigine a line that divides in two the screen of the monitor has remained, I send you the photo that the defect underlines
        I beg someone to resolve this problem.
        thanks to all the friends of the Forum
          Originally posted by gonzo0815
          try to find a datasheet of the transistor in question.
          Then look at the pinout.
          If it is a MOSFET chek for short between gate - source , gate - drain and source drain.
          But keep in kind, there are some MOSFET with integrated protection diode, thus this coul couase erounouse readings.
          Bipolar transistors are similar.
          For detailed instruction goolge abvouth sci faq, read the SMPS repair faq.
          hi
          where I can purchase on Internet the four HEXFETs 4600 of the inverter Ambit T501045.00
          Can I replace them with equivalent?
          thanks for the answer
          mario
            does nobody respond?
            please
            thanks
              This isn't a service marketta, it's a forum and it's free.
              When all else fails the best thing is to do a google search for the part number.
              Also if you search the forums before asking, many questions are already answered:
              https://www.badcaps.net/forum/showthread.php?t=613
              Mann-Made Global Warming.
              - Dr Seuss
                thanks and you excuse
                a regard
                mario
                  No worries Mario.
                  - Dr Seuss
                    ok
                    thanks
                      i don't know if they can be found/crossreferenced. i have look and nothing. no data sheets either. maybe it could be a generic one but how wants to do the trial and error associated with finding the right one. a schematic would help. if current values were know, a suitable replacement could be substituted. an electrical engineer could figure it out.
                      dave
                        Thanks of the answer Dave
                        the substitutes of the HEXFETs 4600 of the inverter Ambit T501045.00 is the HEXFETs IRF 7389
                        kindly one friend of ours of the forum has given me this link
                        thanks
                        mario
                          mario
                          thanks.
                          i will order a few and i will also look up the reference sheet.
                          that link is for suppliers. i guess its good.
                          where did you get the info about the hexfet?
                          dave
                            hi Dave
                            The information I have found her on our forum
                            you/he/she has given her for me PCBONEZ
                            hi
                              PCBONEZ <- Is a he ...
                              - Dr Seuss
                                Don't worry, it's a Babelfish side effect: replace her with informations I needed.
                                @ marketta: volevi scrivere "L'informazione l'ho trovata sul forum, me l'ha data pcbonez" ?
                                Zandrax
                                Have an happy life.
                                  you excuse my poor man English
                                  I use a translator
                                  hi to everybody
                                    I wasn't worried.
                                    I was playing...
                                    - Dr Seuss
                                      no problem
                                      and thanks for the help for the hexfets
                                      hi
                                      I go to sleep in italy they are the 1,49 of the morning
                                      good night
                                        the link if for
                                        "Global Sources for Aluminium Electrolytic Radial Capacitors"
                                        i know that these companies carry more that just caps. i have searched there wedsites and cat. only to come up short. i have looked for a manufacture with a capital 'A' in the circls, nothing. i have asked the sellers of the boards of they could help, nothing.
                                        i won't give up just yet but i can see how a link to digikey ect. is going to help.
                                        dave
                                          This forum is a veritable gift. I am working on a W1700 with the described problem and yes, one of the fuses is open. I have the capacitors (Rubycon) but not the fuses. But one thing is bothering me.
                                          Some posts refer to fuses soldered over, or fuses failing repeatedly. We are working with a switching power supply, which means waveforms with short rise-times and high peak currents. In shopping for parts I notice that chip fuses are available as slow-blow and quick-blow types. I'm thinking what is really needed here is a slow-blow fuse, but I don't have any manufacturer's data. I don't want to assume - we all know how that turns out! Input anyone?
