Yusmart 229IP-P 22" LCD Monitor Dead
+ More Options
Posts
  • bonney
    • Oct 2008
    • 74
    #61
    Re: Yusmart 229IP-P 22" LCD Monitor Dead
    sorry for the quality
    you should just make out pin 9 is not joined
    • jetadm123
      • 2169
      #62
      Ah, I see. It wasn't as obvious in post #11, but your photo makes it clear. Thanks for checking. Also, in your first post, you mentioned that it was an eeprom that was was the cause of your problem. Can you share how you came to that conclusion and how you tested it? What is the part # of the eeprom and whether or not you had to program it. Thanks.
      • bonney
        • Oct 2008
        • 74
        #63
        I had a Viewsonic with similar board and the same symptoms that was the eeprom
        • jetadm123
          • 2169
          #64
          Great! You just jarred my memory. PlainBill had discovered a reset controller, ASM810MEURF-T (not an eeprom), used on several Acer and Viewsonics that exhibited the same problems here. Replacing that controller solved the problem. Since this monitor seems to be similar to a viewsonic, can you tell if they implemented a reset controller on the Yusmart logic card? It's a SOT-23 case style.
          • fusionmax
            • Sep 2010
            • 42
            #65
            I have sccanned the board and listed the SOT-23 package chipsets that I can see....
            I have been trying to identify them from what little info they have on the chips but haven't been very successful so far
            • PlainBill
              • Feb 2009
              • 7034
              This site has information on marking codes. You are correct, many of these codes don't appear in the references.
              PlainBill
              • bonney
                • Oct 2008
                • 74
                #67
                I would of thought MMBT3906 or PMBS3906
                • jetadm123
                  • 2169
                  #68
                  Hmmm, I can't see them using three WO4 as a reset controller. KL8 seems to be a diode assembly. That leaves SO1, marked Q104 on the circuit board. I would think that the reset controller would be marked UXXX?
                  • bonney
                    • Oct 2008
                    • 74
                    #69
                    The main board in this service manual uses TSUMU58WJ
                    • PlainBill
                      • Feb 2009
                      • 7034
                      That shows a simple R/C reset circuit, although the board has provision for a reset controller.
                      PlainBill
                      • fusionmax
                        • Sep 2010
                        • 42
                        #71
                        I'm starting to think this might be a lost cause
                        • bonney
                          • Oct 2008
                          • 74
                          #72
                          I have another logic board on the way, will try and compare then
                          • fusionmax
                            • Sep 2010
                            • 42
                            #73
                            Completely unrelated I know but just on the off hand...... can anybody identify the component in the image below for me?
                            It only has a marking of 0, is it a smd capacitor?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #74
                              It's a zero ohm resistor. Basically a wire link, but making it in this shape enables the same machine that places resistors and caps to place the wire links as well.
                              A working TV? How boring!
                              • fusionmax
                                • Sep 2010
                                • 42
                                #75
                                Thanks for that, I assume I could replace them with a jumper wire without any issues?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  #76
                                  Umm, why, it isn't showing continuity?
                                  • fusionmax
                                    • Sep 2010
                                    • 42
                                    #77
                                    No, it is a damaged board. A few of them have been smashed off so I was planning on just replacing them with a jumper.
                                    It is only a control panel so hopefully there should be no RF issues
                                    • Whitey
                                      • Jan 2011
                                      • 4
                                      #78
                                      I have a Benq LCD tv model VP2202 which uses the same power supply as the Yusmart 229IP-P & the Viewsonic VX2235WM-3 Model # VS11446.
                                      My issue is I am trying to get a copy of a service manual to find out what each of the output pins are on the ps board at P802 for example voltages and what they control BRT_ADJ, BL_ON, GND & so on.
                                      I tried the link given in post #1 & #16 but it won''t allow access to the service manual.
                                      I would appreciate if anyone has a pdf copy they could send me.
                                      or even just what the wires do.
                                      The old ps in this tv is completely fried so I am trying to adapt one I have from a Benq FP91G Monitor to suit.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #79
                                        http://www.scribd.com/doc/31616590/V...-vx2235wm-3-sm
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • Whitey
                                          • Jan 2011
                                          • 4
                                          #80
                                          Thanks retiredcaps for the link unfortunately I dont have a credit card or paypal account.
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                          • Rick_1234
                                            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                            by Rick_1234
                                            Good evening, gentlemen.
                                            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                            https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                            Things I tried
                                            - Bought a new AC adapter thinking that was the problem but the problem...
                                            06-22-2024, 04:44 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
