Dell 1707fpt's transformer smells badly
  • uligli
    • Aug 2006
    • 139
    I bought a few bad monitors two day ago, one of them is a Dell 1707fpt, it work fine except when it's on some bad smell come out, i find out the bad smell comes from one of the transformer, should i replace it?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell 1707fpt's transformer smells badly
    I don't see a replacement part for your transformer at
    http://lcdparts.net/T.aspx
    but it looks like a replacement will cost around $20 USD. To me, it wouldn't be worth $20.
    I don't know what the costs are in your country is, but sometimes (not very often) I see ads for used 19 inch LCD monitors for $20 CDN.
    It looks like you recapped the board too with United Chemicon.
    --- begin sig file ---
    --- end sig file ---
    • uligli
      • Aug 2006
      • 139
      No i did'nt recap it, i was surprised when i saw the logic board and inverter board full of UC caps. It's worth spending $20 reapairing this monitor to me. Thanks for the website
      • Toasty
        • Jul 2007
        • 4171
        Does it get hotter than the other?
        Could it be bad CCFL tube(s)?
        Have you tried switching tube connections from one side to the other?
        Whole board: http://www.lcdrepair.us/1707-1907FPt...ter-power.html
        p/n: 6832165100P01 aka: PTB-1651
        veritas odium parit
        • uligli
          • Aug 2006
          • 139
          I turn it on for 20 - 30 secs and works fine, i turn it off quickly after smell the bad odor, so i don't think it could be bad CCFL tubes.
          • uligli
            • Aug 2006
            • 139
            Updates (divided 3 parts)
            update #1
            I find out that the odor actually comes from a burned ccfl's female connector, there is a burned spot that's quite obviously, doh
            • uligli
              • Aug 2006
              • 139
              update #2
              I took a connector from another board, not the exact same size so i bend the legs a little. After soldering it without any problem i turn on the monitor, the burned chemical odor was gone, but i still smell the chemical odor. I opened the monitor again and measured most of the surrounded components of that female connector:
              c108 - 692 ohm
              c109 - 429 ohm
              c143 - no reading
              R111 - 249 ohm (SMD resitor marked as 4320)
              R112 - 994 ohm (1001)
              R115 - 3.62k ohm (1598)
              R120 - 12.96k ohm (1302)
              all diodes read 616-622
              I think may be the ceramic cap is bad (N27 3KV SEC), interesting that i notice a glowing cable in the back of the monitor.
              • uligli
                • Aug 2006
                • 139
                update #3
                So i turned on the monitor without the backcover, and definitely the ccfl's cable attached to the bad connector was glowing purple blue, i tried connect to another side and still glowing, i guess the problem it's a leaking ccfl tube, am i right? Should i change the ceramic cap too?
                P.S: the monitor doesn't have any brightness or display problem, completely functional, except for the smell.
                • uligli
                  • Aug 2006
                  • 139
                  Toasty was right about the CCFL's tube
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    I don't know what would cause that wire to do that. Hope someone else can tell you!
                    -David VanHorn
                    • Quasar
                      • Sep 2010
                      • 132
                      Glow is corona effect on wire. High voltage. Are those wires going to the CCFL tubes? A bad tube might cause that as the HV has no where to go, no load.
                      • uligli
                        • Aug 2006
                        • 139
                        Yes, those wires going to the CCFL tubes.
                        • Quasar
                          • Sep 2010
                          • 132
                          Then replace the CCFL's and the connector and you should be fine.
                          • uligli
                            • Aug 2006
                            • 139
                            Should i replace the ceramic cap too?
                            • Quasar
                              • Sep 2010
                              • 132
                              Unless it is visibly failed, I have found them to generally be okay. I would not replace it. Maybe check it to be sure it is not shorted, but I think it will be fine.
                              • uligli
                                • Aug 2006
                                • 139
                                Thank you Quasar
                                • uligli
                                  • Aug 2006
                                  • 139
                                  I opened the LCD panel and effectively a lamp was broken, put a pair of 1703fps ccfl's tubes (upper ones) which are very similar in size, trying to put to the panel all together took me an hour unfortunately i f' up the the lcd screen while assambling (pressure marks) at least it works but with faulty display.
                                  Thanks to everyone who tried to help.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4951
                                    • New Zealand
                                    Could you take a photo of the pressure marks? I would be interested to know what they look like for future reference.
                                    -David VanHorn
                                    • uligli
                                      • Aug 2006
                                      • 139
                                      Sorry i've been busy, didn't have time to take the pics. After few days of "resting" the defects on the screen have been changed (now visually is more acceptable than before).
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • F R 2568
                                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                                        by F R 2568
                                        Hello all,
                                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                        If the laptop is only connected to the AC adapter (battery removed):
                                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                        The power/battery...
                                        01-08-2025, 05:45 AM
                                      • diamon
                                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                        by diamon
                                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                        Pictures of these boards:
                                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                        Dell...
                                        02-28-2024, 12:51 PM
                                      • master3112
                                        by master3112
                                        Today, 01:55 PM
                                      • OntarioTL
                                        Dell 5410 greyed out BT
                                        by OntarioTL
                                        Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                        If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                        Dell Lattitude 5410
                                        Service Tag...
                                        07-25-2025, 01:28 PM
