I bought a few bad monitors two day ago, one of them is a Dell 1707fpt, it work fine except when it's on some bad smell come out, i find out the bad smell comes from one of the transformer, should i replace it?
Dell 1707fpt's transformer smells badly
Re: Dell 1707fpt's transformer smells badly
http://lcdparts.net/T.aspx
but it looks like a replacement will cost around $20 USD. To me, it wouldn't be worth $20.
I don't know what the costs are in your country is, but sometimes (not very often) I see ads for used 19 inch LCD monitors for $20 CDN.
It looks like you recapped the board too with United Chemicon.--- begin sig file ---
--- end sig file --- -
Does it get hotter than the other?
Could it be bad CCFL tube(s)?
Have you tried switching tube connections from one side to the other?
Whole board: http://www.lcdrepair.us/1707-1907FPt...ter-power.html
p/n: 6832165100P01 aka: PTB-1651
.Last edited by Toasty; 08-22-2010, 10:26 PM.veritas odium paritComment
.Comment
update #2
I took a connector from another board, not the exact same size so i bend the legs a little. After soldering it without any problem i turn on the monitor, the burned chemical odor was gone, but i still smell the chemical odor. I opened the monitor again and measured most of the surrounded components of that female connector:
c108 - 692 ohm
c109 - 429 ohm
c143 - no reading
R111 - 249 ohm (SMD resitor marked as 4320)
R112 - 994 ohm (1001)
R115 - 3.62k ohm (1598)
R120 - 12.96k ohm (1302)
all diodes read 616-622
I think may be the ceramic cap is bad (N27 3KV SEC), interesting that i notice a glowing cable in the back of the monitor.Comment
update #3
So i turned on the monitor without the backcover, and definitely the ccfl's cable attached to the bad connector was glowing purple blue, i tried connect to another side and still glowing, i guess the problem it's a leaking ccfl tube, am i right? Should i change the ceramic cap too?
P.S: the monitor doesn't have any brightness or display problem, completely functional, except for the smell.Comment
I opened the LCD panel and effectively a lamp was broken, put a pair of 1703fps ccfl's tubes (upper ones) which are very similar in size, trying to put to the panel all together took me an hourunfortunately i f' up the the lcd screen while assambling (pressure marks)
at least it works but with faulty display.
Thanks to everyone who tried to help.Comment
Could you take a photo of the pressure marks? I would be interested to know what they look like for future reference."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos - Loading...
