Xerox XL775D
+ More Options
Posts
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Xerox XL775D
    Hi has anyone come across this problem with these monitors before
    Started asa 2 sec to black so i changed the inverter no joy
    Changed bulbs still no joy
    So tried changing caps on main board
    10 16v 220uf and 5 16v 100uf and still cutting out
    Not sure now which way to go
    any help or ideas would gratefully accepted
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Xerox XL775D
    1) What replacement caps did you use?
    2) See "A guide on how to troubleshoot 2 seconds to black"
    https://www.badcaps.net/forum/showthread.php?t=10419
    look at transformer section, but read through everything to doublecheck.
    3) Post clear focused pictures AFTER reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    Take your boards to a window on a sunny day and use macro mode. Take a top down view of all your boards (front and back).
    --- begin sig file ---
    --- end sig file ---
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      Re: Xerox XL775D
      Hi thanks for reply
      The caps have no name that i can see
      220-16PHT 220uF 16V 105'c have NA and
      100-16PHT 100uF 16V 105'c have a large H
      Bought from little diode
      Look again and they dont say low esr but assume they were
      The inverter board is a seperate from the main board and is new
      Will upload picture of board later as its dark here (UK)
      Took this on cam phone not very good but gives some idea of board
      Paul
      • seanc
        • Nov 2008
        • 1319
        Re: Xerox XL775D
        Is your external PSU putting out the correct and stable voltage?
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Re: Xerox XL775D
          HI all well my thanks go to retiredcaps and seanc more for reminding me to check the basics before looking for the less obvious
          Popped the power supply open to find wait for it
          a bad cap
          changed this and now all working fine
          Have found this site extremly useful in the past and sure i will do in the future
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Xerox XL775D
            Sometimes it just takes a pair of fresh eyes!
            I remember one university assignment where my friend spent 4 hours debugging his assembler code. He asked for my help and in 2 minutes I found the problem. It was something pretty simple, but he was so buried in details he forgot to check the simple things.
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              Re: Xerox XL775D
              Like i said just forgot to check the simple things first
              caps were gone but original inverter ok so now have a spare
              Well 3 actually bought some in save waiting in future
              Thanks again for your help will probably be bugging you again soon
              • Alfieh
                NAD C320BEE repair possibly bad capacitors
                by Alfieh
                hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                11-19-2024, 04:55 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • mido50
                xerox phaser 3330
                by mido50
                I need a xerox phaser 3330 moded firmware that make the printer work without drum & carriage chips
                12-31-2024, 12:30 PM
              • pc_okay
                Xerox Versalink C505 bad printing in color mdoe
                by pc_okay
                Hello friends,
                I have a problem with this printer Xerox Versalink C505 , printing perfectly in B&W but bad in color.
                There is a little yellow ghost printing around color print.
                So little text in color is unreadable.
                I already change drum cyan & yellow with no success.
                I try (i think) all avalable calibration in printer menu..
                (black drum is dead but it's not the problem i think)
                I'm not a printer specialist,if anyone has an idea?
                Thanks !...
                12-01-2024, 09:08 AM
              • panoss
                Samsung LS19A100, slowed down, colors changed, lines not very crisp
                by panoss
                In the above mentioned monitor, I removed the plug a few times and this resulted no power.
                I opened it, soldered the dc jack and worked again.
                But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
                I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
                IC600 (D9329)
                pin 1 (BST) 9.6V
                pin 2 (VIN) 13.5V
                pin 3 (SW(Switching output)) 4.8V
                pin 7 (EN)
                pin 8 (SS) 2.6V
                IC601...
                10-13-2024, 10:21 AM
