Behringer Eurorack UB2442FX-PRO Bad Capacitors
    • 31214
    Re: Behringer Eurorack UB2442FX-PRO Bad Capacitors
    Originally posted by mehranpak
    please help me . thanks .
    Hi
    Please help me.
    One kind to me and say how much the order of the output voltage of a power supply pins?
    Please answer faster.
    What makes the mixer rips? Lds is off and caustic
    very thanks.
    behringer UB2442FX-PRO
    • ve3vxo
      • Jul 2014
      • CDN
      One thing I forgot to mention in my post above. The Panasonic replacements for C12 and C16 (1000 uF/25v) are 30mm tall but the original Xunda caps were 20mm. This is significant in this case. I had to modify the power supply case and even so there was a slight interference between the case and the main board of the mixer. Since I didn't know the original specs of the Xunda caps I trusted the wisdom of the group and bought these panasonic caps but if you can find shorter ones it would be wise.
        • 31214
        what was printed on the old caps?
        http://www.paullinebarger.net/DS/Xunda/
        • ve3vxo
          • Jul 2014
          • CDN
          Huh. I just got this notice from digikey regarding the C7 150uF 400V:
          Parts Affected
          Manufacturer PANASONIC ELECTRONIC COMPONENTS
          Description CAP ALUM 150UF 400V 20% SNAP
          Manufacturer Part Number EET-ED2G151CA
          Digi-Key Part Number P11649-ND
          Status End Of Life
          Last Time Buy Date 03/31/2015
          Possible Substitutes
          Manufacturer Part Number Digi-Key Part Number Description Manufacturer Lead Content RoHS Status
          381LR151M400J022 338-2480-ND CAP ALUM 150UF 400V 20% SNAP CORNELL DUBILIER ELECTRONICS (CDE) Lead free RoHS Compliant
          • ve3vxo
            • Jul 2014
            • CDN
            @stj they were Xunda types. I already tossed them. (with malice)
            • Jose Manuel Borges
              • Apr 2015
              • Portugal
              #26
              Friends have a BEHRINGER mixing console EURORACK UB2442FX-PRO, which is a number of problems, I have no great esperiência in the repair of such devices,
              1 only has signal input on channel 1 and channel 4, the other gives nothing.
              2 in the signal input to the tape, just enter sign on the right channel.
              3 only has signal output on the right.
              I would appreciate someone can help me on this repair.
              • midibob
                • Nov 2008
                • 285
                #27
                Have you investigated anything I suggested in your original thread??
                Midibob
                  • Apr 2015
                  • Portugal
                  #28
                  Midibob
                  No, I lost myself in the forum , because I'm new here, I do not know how to do, so I put here again , I'm sorry .
                  • riboild
                    • Aug 2016
                    Not trying to resurrect an old thread but I have the same mixer and i replaced all the caps thinking that would fix my problem then come to find out one of the resistors is burnt. Is there anybody with a good working powersupply that can take some pictures of the resistors and post on here... i can't find a place that shows what was supposed to be there and since it is burnt I can't read the bands. Thanks!!!
                    Thomas
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8331
                      Can we see straight shot, high resolution pictures, please?
                      The service manual has all the schematics "but" the PSU off course.
                      I've dug up this one on my computer, but google something like "Behringer UB SMPS .pdf or PSU and google will be gladly return more schematics, even when you click on pictures.
                      • Deano555
                        • Oct 2016
                        • england
                        #31
                        Hi im new to this forum but find it very helpful, I have this mixer and I have replaced all the capacitors but im still getting a low voltage from one rail 14 v where it should be 15 please can anyone help of what i need to change next
                        kind regards
                        Dean
                        • euromatlox
                          • Mar 2013
                          • 60
                          • Finland
                          #32
                          I have that UB2442FX-PRO mixer, no repair done, and not been used long time. I can look inside it, if it helps someone. However, please provide a picture and good explanation, what should be looked at.
                          • Thermaltake
                            Power button on Behringer Xenyx 1204USB mixer dead ?
                            by Thermaltake
                            Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                            I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                            08-16-2022, 03:22 AM
                          • Longon
                            Behringer Pro Mixer DJX-750
                            by Longon
                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                            08-11-2025, 02:17 PM
                          • Thermaltake
                            Behringer xenyx x1204usb mixer
                            by Thermaltake
                            Hi, I have few questions
                            1. few of my pots on mixer are turning so hard, I tried to clean them and spray some DeoxIT Fader spray in it, but it didn't help. Is there any way to put some grease inside that pots whole that is on the side instead of spraing in it ?
                            2. Or is it just simpler to replace them all with same ones ? I am not into pots, so am I able to put some better quality ones or it needs to be same one as they were default ?...
                            09-17-2024, 10:57 AM
                          • dragon3x
                            by dragon3x
                            power on.
                            Here are some examples :
                            switching supply area).
                            than 6.3 V.)
                            03-21-2025, 02:46 PM
                          • dicky96
                            Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
                            by dicky96
                            Hi guys
                            I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
                            When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
                            Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
                            I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
                            I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU...
                            10-29-2021, 03:56 AM
