PS Audio SPR-A1 ,No audio from Right channel Can anyone help?
  • zen
    • 511
    Hi all
    Can anyone help?
    • 21241
    Re: Hi all No audio from Right channel Can anyone help?
    Originally posted by zen
    Hi all
    Can anyone help?
    It might help if we knew what the hell it is
    • zen
      • 511
      Never seen one of these before but it's a Small amp manufactured by PS Audio.
      I believe the model is SPR-A1
      Known as the Sprout.
      Apart from that i literally cannot find any other info on this thing.
      • petehall347
        • Jan 2015
        • 4428
        • United Kingdom
        compare signals for each channel and see where it stops .. you will need data sheets for the ic.s first .
        • CapLeaker
          Leaking Member
          • 8232
          I guess it would help if we could see the boards first place?!
          • zen
            • 511
            Re: PS Audio SPR-A1 ,No audio from Right channel Can anyone help?
            R333 (3R9) O/C
            Suspect it has been taken out by IC302 which i need help to identify.
            It's marked Abletec.com C1 & below that is 306P
            • CapLeaker
              Leaking Member
              • 8232
              Swap the good IC where the bad IC was, fix the resistor and see what happens.
              Edit: plenty of abletec.com C1 on AliExpress.
              • zen
                • 511
                Hi,don't want to cause more damage as components around the suspected faulty chip blown.
                Ordered a chip from Ali , but not sure if the 306P marking has any significance , or is some sort of batch code.
                • dicky96
                  American Audio VLP1500 Distorting on one channel
                  by dicky96
                  Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                  Protection and Clip LED are off
                  There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                  I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                  The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                  07-13-2022, 05:25 AM
                • akarta
                  Onkyo TX-SR702 no audio after channel repair
                  by akarta
                  Really strange one. Got this amp with digital noise coming from all channels. BAD cap on 12V rail and burned via on -12V rail causing -7V and +7V rails missing, audio noise and "SP CONFIG" message (thinking that MIC is plugged in then it is NOT, but before I replaced cap and fixed rails I have accidently left it ON with output transistors for rear channels hanging in air (NOT HEATSINK ). One channel blew. After further inspection found a LOT of caps out of range on DSP and Processor boards. Replaced every single one that did not pass my ESR test(almost all).Got receiver back together...
                  05-02-2022, 08:54 AM
                • eccerr0r
                  old X58 triple channel board... memtest86 memory speed?
                  by eccerr0r
                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                  06-28-2025, 09:06 AM
                • spleenharvester
                  Reverse engineering of 18650 4-channel tester
                  by spleenharvester
                  Hi friends
                  I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                  05-04-2025, 02:43 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
