Onkyo TX-SR702 no audio after channel repair
  • akarta
    • Nov 2015
    • 16
    Really strange one. Got this amp with digital noise coming from all channels. BAD cap on 12V rail and burned via on -12V rail causing -7V and +7V rails missing, audio noise and "SP CONFIG" message (thinking that MIC is plugged in then it is NOT, but before I replaced cap and fixed rails I have accidently left it ON with output transistors for rear channels hanging in air (NOT HEATSINK ). One channel blew. After further inspection found a LOT of caps out of range on DSP and Processor boards. Replaced every single one that did not pass my ESR test(almost all).Got receiver back together (Output stage repaired as well) and to my surprise NO AUDIO. Output relays do click in and could hear hissing. No protect messages come on FL display. Did diagnostic test 4-21 and above. All channels report "Protect NG". In normal mode if I press Pure Audio button I can hear music out of my speakers if volume set to 100 and I have my ears against speaker. Now the measurements:
    VOLH: 0.00V (service manual does not tell that should be good range)
    PROTECT: 0.00V (0 means protection not triggered, 3.3V do trigger protection if I inject voltage )
    THERMAL: 0.00V Don't know that value should be
    I have notice that processor is keeping MUTE line HIGH. If I pull it LOW I am getting audio on PURE AUDIO mode, but not in DIGITAL mode. Pressing mute on remote I get no audio but MUTE message on display.
    Spend 3 days on this amp and now I hit the wall. Anyone had something similar? That should be VOLH value?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    Re: Onkyo TX-SR702 no audio after channel repair
    Make sure nothing is stuck in the headphone jack. Maybe see what it does with a head set connected. Also look at the the power rails on the digital board to see if all the chips power up. Next you could try to press on components or use heat and cold on certain IC.
    • MegaZAC
      Onkyo TX-SR805 noise in one channel
      by MegaZAC
      Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
      Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
      There's some logic behind it. As soon as I select an input I get only left...
      04-23-2025, 10:09 PM
    • eccerr0r
      old X58 triple channel board... memtest86 memory speed?
      by eccerr0r
      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
      06-28-2025, 09:06 AM
    • spleenharvester
      Reverse engineering of 18650 4-channel tester
      by spleenharvester
      Hi friends
      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
      05-04-2025, 02:43 AM
    • mikey5791
      Help on car amplifier only one channel works
      by mikey5791
      Hi all forum members,
      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
      08-06-2025, 10:36 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
