Yamaha EMX 2000 Powered Mixer issue
  • Phlox321
    • Jan 2014
    • 37
    • South Africa
    Hi All
    I have a yamaha emx 2000 powered mixer im trying to repeair.
    the problem is that theres no sound output on the right channel. Left channel works fine.
    Right channel has output when using the phono(headphone output) but not when going through the amplifier
    the left peak meters work but not the right
    the clipping light however does come on when gain is turned up same as left channel
    What i have done so far is make sure that the supply voltages are fine, which they are
    I found several cracked solder joints on the amplifier board which i have resoldered but made no difference
    i replaced the stereo fader and 2 of the stereo input faders as it looked like the tracks on them had no carbon left ( tracks where white) and i got weird readings of like 180K ohm out of a 10K slide pot
    that still made now difference.
    there is a bit of sound coming from the output when everything is set to full volume and gain. i probed around some more, and so far ive just found a 100k resistor in the signal path of the right channel reading about 66k ohm
    not sure if that could cause the issue
    I have uploaded a service manual i found
    any ideas?
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: Yamaha EMX 2000 Powered Mixer issue
    are you sure the muted cchanel is not blowed?take measurements and comppare the output devices with the good chanel see if voltage is the same to booth chanels.disconnect from mains and chek all the trans and resistors on output with dmm.chek if supply rails to the amp after the filter capacitors is present.
    • Phlox321
      • Jan 2014
      • 37
      • South Africa
      Hi
      I Made a contraption i read about on internet from someone else troubleshooting a mixer.Basically you inject a sine wave ( from phone or something else) and use a multimeter probe with one end grounded and capacitor added and the other end to poke around. The probes are connected to an amplifier with speakers. That way you can trace and hear where the signal gets "lost"
      I thought at first it could have been the input section but thats fine, get sound on both channels.
      I narrowed it down to the incoming signal to the master volume slider , or that region.
      I took a chance and briged the working left channel 10k slide pot pin to the right channel and it worked. The VU lights up both channels and i get output to the amplifier on both channels. Not stereo , but i just checked to make sure the amplifier section wasn't blown and it is fine.
      So looks like the signal is not getting to the master fader.
      just cant pin point exactly where.
      All the op-amps on left and right channel and master fader seem to be fine. get input 14v and output 14v, not sure how to test them really.
      Only Wierd thing is i get around 30V +- to Op amp however in schematic its shows 15v+- (but the PSU outputs are fine)
      The mixer seems to be working fine though.
      Will check anyway to see where the 15v supply comes from and if it really is 15v +- or 30v +-
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
      • MobileXT
        Yamaha DXR15 Powered Speaker Fault LED On
        by MobileXT
        Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here...
        01-17-2025, 12:43 AM
      • sukaht
        Yamaha MSR400 - Powered PA Speaker
        by sukaht
        Hello everyone.
        I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
        It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
        I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
        11-02-2024, 07:55 PM
      • HelpMeRepair
        Yamaha RX-A3010 left channel no signal
        by HelpMeRepair
        Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
        what I did so far ,
        factory reset
        test all other channel
        tone test
        dissasemble and look , visual inspection witout full dissasembly
        looked at all the mosfet for temperature to see if they eas operating
        scratch my head couple of time
        thanks in advance all help is appreciated , service manual are welcome too ! =)...
        11-14-2024, 02:48 PM
      • spleenharvester
        Reverse engineering of 18650 4-channel tester
        by spleenharvester
        Hi friends
        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
        05-04-2025, 02:43 AM
