Yamaha DXR15 Powered Speaker Fault LED On
  • MobileXT
    • Oct 2012
    • 200
    Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here
  • madan1
    • Nov 2016
    • 682
    Well, start with the power supply - page 99 -> +/-VB, VDR, +VS, +/-18A, +5V. Check if all that power rails are present. Then check the DSP board and see if the +/-15, +6V, +5 and +3.3 rails are generated.
    • MobileXT
      • Oct 2012
      • 200
      Thank you! and found that Q107 was shorted to ground. I order the replacement parts and I will update soon once I get the parts.
      • MobileXT
        • Oct 2012
        • 200
        Update: After replacement of the Q107 still have the same issue Q107 still getting hot from the infrared camera. Q106 is not shorted, I Removed Q106 and there's no reading on the diode mode drain and source. Testing D10 with Diode Mode seems like D104 is not shorted.
        • madan1
          • Nov 2016
          • 682
          If you have a red LED or indeed any other LED, then you have +5LD rail, +6V, +18A and DC+25V power rails, all of them are on the secondary/low-voltage side of the power supply. This most likely means that the primary side is working.
          • MobileXT
            • Oct 2012
            • 200
            That’s good to know, I will concentrate on the secondary or the amp output. Thanks for the tips.
            • MobileXT
              • Oct 2012
              • 200
              After hours, days and months of trouble shooting. I finally ordered the AMP board and replaced it with a new one. Sadly, still have the same problem Protection mode still ON. I did all check the power rail on the DSP and all the power rail are present. So I did check on the tweeter AMP and measure 27V at the speaker output. SO I am pointing to the AMP IC TDA8922CTH is BAD but I need you guys expert on this one.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8178
                Yeah… switched wrong amp board. Remove the TDA IC from the board and reinstall the board see if your DC disappears on the tweeter.
                • MobileXT
                  • Oct 2012
                  • 200
                  Okay After removed the TDA the 27V at the tweeter output still present. I attached a measurement after removal of the TDA.
                  • R_J
                    • Jun 2012
                    • 9548
                    `What point are you using for ground when checking the tweeter voltage? Check what voltage you have ACROSS the tweeter terminals, the supply to this ic is +55v, half would be around +27v measured to PGround
                    The speaker is connected across the two outputs of the ic.
                    Are you able to power on the amp without the tweeter amp board connected?
                    • MobileXT
                      • Oct 2012
                      • 200
                      I measure from ground to the tweeter terminal I got 27V each channel. If I measure from the two Channel ACROSS tweeter output I have 0V without the TDA AMP. Yes I can still power on the AMP without the Tweeter AMP board but I have a Protection circuit ON.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8178
                        You measured the tweeter voltage wrong (should have been like 55V across the speaker terminal), but that’s o.k. At least the speaker works without the tweeter amp. It could be that over the time heating and cooling cycles, the TDA’s legs may develop cold solder joints, thus triggering the protection. At least you are on the right track now.
                        • MobileXT
                          • Oct 2012
                          • 200
                          Thanks CapLeaker! You think TDA AMP chip is Okay to solder it back now?. I ordered a new one should be here now in a couple of days. I have two speakers have the same issue. I might open it up the other speaker check for the legs on the TDA8922CTH legs for cold solder joints.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8178
                            Any class D brick style with these 1000 little legs can develop that problem. My first goto is looking for cold solder joints on the class D brick and then resolder and try. Anything that gets hot and has a heat sink on it. Followed by all power supply rails measurments
                            • R_J
                              • Jun 2012
                              • 9548
                              If you replaced the amp/power board and disconnect CN501 (twamp) and still have the protection led, check CN255 pins 15 (DC_DET) and 16 (AMP_ERR) to see which line is enabling the protection.
                              IC501 is operating in btl (bridge mode) so KG is common or signal ground
                              • MobileXT
                                • Oct 2012
                                • 200
                                Okay! here is the results for the CN255 PIN 15(DC_DET)= 0.020v and PIN 16(AMP_ERR)=3.296V. Measured from the ground to PIN 15,16. without the Tweeter amp board.
                                • R_J
                                  • Jun 2012
                                  • 9548
                                  Looks like DC_DET is logic low, not sure what it should be I suspect it should be +3.3v . There is a DC detect check test point (page 104 k,3) it seems to have logic levels, check those pins, maybe it will show something wrong
                                  This is not a simple system, they monitor a lot of things, and anyone could cause a fault. and they don't really say if a logic high or low is normal operation or with fault.
                                  • madan1
                                    • Nov 2016
                                    • 682
                                    Probably a stupid question, but have you checked the tweeter and the woofer? Are they shorted?
                                    • MobileXT
                                      • Oct 2012
                                      • 200
                                      Woofer and tweeter are not shorted:
                                      Okay I have updates. I fixed the protection mode but now I have no audio input on all 3 channel input. The LED green input indicator won't turn on.
                                      • MobileXT
                                        • Oct 2012
                                        • 200
                                        I have a shorted on the IC713 and IC715 both on PIN 6 & 7 so I ordered the parts from Mouser NJM2068M-D hopefully will get here by next week. Once I get the parts I will update you guys.
                                        • sukaht
                                          Yamaha MSR400 - Powered PA Speaker
                                          by sukaht
                                          Hello everyone.
                                          I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
                                          It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
                                          I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
                                          11-02-2024, 07:55 PM
                                        • JimBanville
                                          Switched speaker impedance selector w/ Yamaha HTR-5740 RX-V450 powered on!! Problem?
                                          by JimBanville
                                          So I didn't realize there was a tiny written warning on the speaker impedance switch on the back that said moving the switch with the power on "may damage the unit". I actually switched it multiple times, listening for any possible audible changes. It wasn't until later I saw the tiny warning. I haven't noticed any issues though. Can someone please look at the schematic and tell me what damage I may have caused? Thanks!!...
                                          01-25-2021, 08:45 AM
                                        • GerryT
                                          Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                                          by GerryT
                                          Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                                          09-17-2023, 10:12 PM
                                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                          what is wrong with your PC in just seconds. It saves you time and money.
                                          Our new and improved design...
                                          11-01-2024, 06:29 AM
                                          HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:30 PM
