I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor. I decided to just go ahead and re-cap the entire board since it was only $20 in capacitors.
I have two general questions:
1. Looking at the discoloration of the circuit board (picture 1), should I be concerned with heat? Like I said, everything does work fine. This picture is before I re-capped it. When I re-capped, I did somewhat try to angle & position the capacitors away from the heat sources as best as I reasonably could.
2. On the main amp backplate, there are several transistors screwed onto it, along with a thermal pad. When I assembled this, I removed the old thermal pad and used heatsink grease instead as I figure this would help with cooling. However, now that I think about it, the thermal pad would be an electrical isolator. Do you guys think I should re-use this thermal pad, or is it ok for the transistors to be attached directly to the amplifier plate like so? The plate appears to be anodized aluminum so it's not conductive on the surface, but of course I don't want to be taking any chances if this is not good practice.
Picture 2 is of how I re-installed these and picture 3 is the thermal pad that came off.
Love to hear your thoughts. Thanks!
