Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Questi
    Originally posted by eccerr0r
    I think the OP's decision to remove the thermal pad is because they "learned" from CPU "delidding" and other ridiculous ideas as to reduce thermal impedance. This is not acceptable for amplifier design because CPU heatsinks tend to be isolated from any electrical potentials (for desktops at least; laptops usually do have some constraints) and even if the CPU shorts to the heatsink, it may not matter as the heatsink is completely shrouded by the computer case.
    Amplifiers do typically require electrical isolation between heatsinks and semiconductor devices due to sharing, if not also for electrical potential requirements since the heatsink may be exposed to the outside of the chassis or even *is* the chassis, as running the case at high voltage potential with respect to ground typically is not a good idea for UL approval.
    So, what your saving is design matters on risk?
    UL approval is good if the inspectors are honest.
    My dad and the owner of his company once bought a UL inspectors approval with liquor and fast women. It had to do with being able to put 1200-foot lbs. of pressure down on a foot holder for an electrical connector in a mobile home electrical junction box. My dad was a plant manager of a sheet metal company that also made electrical junction boxes for mobile homes. My dad has been dead for 20 years.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      usually these things won't fly, people will short the case to what they think is GND and get a large spark and kill the device... getting RMAs for this is a waste.
      There's a lot of things that aren't obvious right away trying to save a few cents to make the heatsink at the same potential as the collector. Just that designers/beancounters trying to save a few cents for that insulator better think long and hard to justify saving the cents... and hence end users should trust the designers that they considered not including it too.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I am abbreviation challenged RMAs?
        Good point I did not consider the beancounters trying to save a few cents. So many angles to consider.
        • nobbnobb1
          • Nov 2019
          • 76
          Wow I really didn't know I'd be opening up such a can of worms!
          I decided to play it safe and clean up the thermal pad for re-use. It's not damaged at all and I also used a thin layer of thermal grease on each side to help it a bit. Everything works fine and runs cool. Glad I caught this earlier and didn't take any chances powering it up without the insulator. Nothing wrong with being conservative.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            I would follow the unit long term for failure or the transistors. Let's say 5 years and then get back to this thread to report if successful.
            No can of worms opened just input from different people with different experiences in the electronic field.
            You ultimately made your own choice on how to handle the situation after considering the feedback. That is all any teacher can ask from a student.
            • rustinjust
              Please help, subwoofer connected to tv, read description below
              by rustinjust
              I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
              Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
              Is there a way of...
              10-28-2023, 07:09 AM
            • rustinjust
              Please help, where can I get a remote for my subwoofer?
              by rustinjust
              I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
              Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
              Is there...
              10-28-2023, 03:43 AM
            • 3d32164
              Identification of a Capacitor for Subwoofer Velodyne
              by 3d32164
              Hi Everyone and thank you to accept me on this forum.
              I'm repairing my Velodyne Sub, a Fiber capacitor is dead but the burn erase part of the writing, can you help me to identify it ?
              I attached the picture.
              Thank you for your help....
              11-18-2022, 01:33 PM
            • harp
              Metod for removing glued heatsink from fragile component
              by harp
              I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
              06-23-2025, 02:01 PM
            • DynaxSC
              Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
              by DynaxSC
              Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
              For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
              06-10-2023, 11:30 AM
