TC158R , Sony cass deck schematic please
  • zen
    • 511
    Hi all
    This unit was working apart from noisy capstan motor .
    Popped off the back cover to clean brushes & lubricate it .
    When tested again it ran for a short while , then no power to deck .
  • lotas
    • Jan 2016
    • 4651
    • Russia
    Re: TC158R , Sony cass deck schematic please
    • redwire
      • 3910
      Check your work- either you didn't put it back together properly or there is a (new) broken connection, bad solder joint, cable connector etc.
      Sometimes working on the motor can cause a short with the built-in servo board or brushes etc. You could try disconnect the motor and see if the unit powers up, or too late and a fuse popped.
      • zen
        • 511
        Thanks Lotas & Redwire
        Suspect a safety resistor has popped somewhere .
        • zen
          • 511
          Really impressed with schematic quality , considering original only available on on paper manual .
          Q401 , type 2SD809-K , which is part of the capstan drive network found to have an O/C B - E junction .
          Replaced using the slightly more powerful BD139 .
          Motor functions now restored
          • zen
            FH7 Sony cass deck service manual & gear required.
            by zen
            Hi all
            This deck keeps jamming.
            Took a chance & ordered an upgraded FF cam gear, plus slider sold on Ebay, as I thought it might be a common cause of issues being that it was sold a repair kit.
            Well, that's what I get for making assumptions.
            Stripped down & discovered a large black intermediate gear with worn teeth.
            Can anyone help to source it?
            10-10-2022, 08:07 AM
          • goodpsusearch
            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
            by goodpsusearch
            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
            05-05-2024, 02:04 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • juergenb
            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
            by juergenb
            i am asking for some Help.
            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
            The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
            So i got a few of these from Banggood.
            I swapped the motor and now i have a new fault condition.
            In a working Frother you would press the start button, it will light red and work for a few minutes.
            If you press longer it will light blue and just mixup the milk.
            With the new Motor it just starts...
            03-23-2021, 11:24 AM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
