FH7 Sony cass deck service manual & gear required.
  • zen
    • 511
    Hi all
    This deck keeps jamming.
    Took a chance & ordered an upgraded FF cam gear, plus slider sold on Ebay, as I thought it might be a common cause of issues being that it was sold a repair kit.
    Well, that's what I get for making assumptions.
    Stripped down & discovered a large black intermediate gear with worn teeth.
    Can anyone help to source it?
  • R_J
    • 9553
    Re: FH7 Sony cass deck service manual & gear required.
    The service manual is online, the part number for the (T) driving gear is 3-307-321-00, The new number was 3-307-321-12, but it is likely NLA
    • zen
      • 511
      Thanks very much RJ
      Potentially have a colleague that may be able to 3D print it for me.
      • zen
        TC158R , Sony cass deck schematic please
        by zen
        Hi all
        This unit was working apart from noisy capstan motor .
        Popped off the back cover to clean brushes & lubricate it .
        When tested again it ran for a short while , then no power to deck ....
        06-13-2022, 07:46 AM
      • goodpsusearch
        Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
        by goodpsusearch
        Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
        First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
        05-05-2024, 02:04 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
