Bose Sound Link Mini II red power light is flashing
  • snoptel
    • Dec 2021
    • 49
    Hi everyone.
    Anyone ever come across a flashing red PWR light? Doesn´t charge, doesn't turn on.
    Tried going to the Bose site and updating firmware but the computer doesn't see it plugged into USB.
    Any suggestions?
    Thanks.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Bose Sound Link Mini II red power light is flashing
    Originally posted by snoptel
    Hi everyone.
    Any suggestions?
    Thanks.
    Easiest way is to call Bose up tell them what is happening. They will take you through at test procedure to correct it. If that does not correct it then there will be something wrong inside. The manual for the equipment should have the different led color codes and flashing or steady codes.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Pull the battery and check for shorts across the battery input on the PCB. The MLCCs can short. Remove each one and test if a short is found. Usually the boost converter is OK.
      Seen this in JBL Charge 3 also. Battery will have 4v or more when disconnected, but drops to zero (protection ckt kicking in) when connected to the PCB. Symptom would be the first battery bar LED flashing, with no power or charging.
      These will work if just one input MLCC is removed; they're paralleled for ripple/ESR.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • MOSSEP
        Monitor Audio RSW12 - Green light, but no sound
        by MOSSEP
        Hi
        Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
        Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
        The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
        I have already tried replacing all of the...
        01-26-2025, 08:33 AM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
      • learnmore
        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
        by learnmore
        Hello Community!
        CASE DETAILS
        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
        Tried inserting firmware on USB and left it in for a few hours, but no change
        03-03-2024, 09:49 AM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • CraigR
        Hp Spectra x360 Power light flashing, component id
        by CraigR
        Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
        05-07-2025, 11:06 AM
