SONOS Play 1 no power burnt out component
  • kalemaroni
    • Jun 2016
    • 196
    I need to replace this burnt out component but don't know what it is. Can anyone help identify it please? It's on the underside of the board.
    2 pictures, one full board, one closeup:
  • R_J
    • 9634
    Re: SONOS Play 1 no power burnt out component
    Fan6751, The is will likely drive a mosfet on the other side and it will also be blown
    • lotas
      • Jan 2016
      • 4936
      • Russia
      In addition to the microcircuit, the R178 resistor burned out, and rather something else, you need to ring its entire harness.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5097
        • New Zealand
        Check your main filter capacitor too. If it's bad, that could be why the MOSFET blew to begin with. The MOSFET snubber network is also suspect.
        I would also check diodes etc around the FAN6751, some may be shorted from the same voltage spike that blew it.
        -David VanHorn
        • lipas22
          • Aug 2016
          • 5
          hi guys .
          can you help please . i need value of R178
          thanks
          • keks19
            • Nov 2017
            • 3
            • Europe
            Hi, R178 measures 148Ohms (in circuit)
            • Goldwing1973
              Sonos Play 1 pulsing power supply
              by Goldwing1973
              I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
              So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
              Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
              The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
              But, whats is not normal is the pulsing of resistor...
              07-04-2025, 12:59 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • dbuergi
              Sonos Play 1 Gen. 2 with no power
              by dbuergi
              i got a Sonos Play 1 Gen. 2 with no light and no power. Until now i only worked on Gen. 1 and know which components "like" to blow up but at this board everything looks fine. Until now i also didn't find any short.
              The only problem i found was chip 6D9 heating up to 110c when power supply is connected. Since this is a PMIC i will replace it.
              Do you have any other ideas what to check or can these chips get faulty without any other component quitting the job?
              09-12-2024, 12:23 AM
