SONOS Play 1 no power burnt out component
Tags: None
Re: SONOS Play 1 no power burnt out component
Check your main filter capacitor too. If it's bad, that could be why the MOSFET blew to begin with. The MOSFET snubber network is also suspect.
I would also check diodes etc around the FAN6751, some may be shorted from the same voltage spike that blew it."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Assuming...7 Photos -
by Goldwing1973I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
But, whats is not normal is the pulsing of resistor...-
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by dbuergiHi all,
i got a Sonos Play 1 Gen. 2 with no light and no power. Until now i only worked on Gen. 1 and know which components "like" to blow up but at this board everything looks fine. Until now i also didn't find any short.
The only problem i found was chip 6D9 heating up to 110c when power supply is connected. Since this is a PMIC i will replace it.
Do you have any other ideas what to check or can these chips get faulty without any other component quitting the job?1 Photo-
09-12-2024, 12:23 AM -
- Loading...
