Philips BDL4221 Speakers too loud
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I figure this is the best place to ask this...
    Have a Philips BDL4221 monitor, thrown out at work, but it doesn't have the speakers. On the back of the monitor, there are hi-fi speaker connectors, the black and red springy connectors for left and right.
    I have a couple of speakers from a mini-hifi that I connected up, and while the sound is awesome, it's way too loud, at 0 and 1 there is no sound at all, go to 2 and it's very loud, and it does increase up after that. If I was using it for anything else, I might be able to lower the volume on any other box going into the monitor, but I've only been using it with a Dreamcast (monitor in TATE mode, through a VGA box), and the DC doesn't have any volume control.
    Any cheap and quick ways to lower the volume, maybe some components on the wire from the speaker?
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Re: Philips BDL4221 Speakers too loud
    Just to add to the info, the speakers are JVC SP-UXLP5, with power handling capacity of 35W, and 6 ohm impedance.
    According to the specs for the monitor, they originally came with "2 x 10 W RMS Speakers".
    Do I risk damaging the audio output of the monitor using these speakers?
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Looks like there is integrated amplifier on this monitor/TV set.
      Try to find the specs, especially the minimum ohms supported.
      Thought, I don't think 6ohms speakers would be bad in case monitor supports 8ohm speakers.
      Anyway, don't connect 4ohm speakers unless officially stated they are supported.
      About the volume issue, could be something wrong with the amp or a terrible mismatch of the new speakers with the old ones (sensitivity, etc) but I think this is not the case
        Philips F9217L-50R speakers – build quality impressions and DIY surround repair
        by momaka
        More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
        02-15-2022, 12:43 AM
      • goodpsusearch
        Philips 170x6 17inch monitor VGA DVI and stereo Speakers repair
        by goodpsusearch
        This is a sad repair story.
        I found 4 monitors, all having their panels scratched from the previous owner in order to destroy them and prevent anyone who gets them to be able to reuse them.
        I took them in, hoping that they would be repaired and the panels still OK despite the scratching.
        Turned out all of them had badcaps on psu.
        PSU is Delta Electronics, excellent design, but uses the usual mediocre non Japanese capacitors.
        The reason the caps bulged is that Philips didn't make enough ventilation holes on the aluminum...
        01-16-2022, 11:32 AM
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
      • logocar3
        Philips 288P6LJEB/27 monitor PSU outputting 8V instead of 12V
        by logocar3
        I am having problem with fixing Philips 288P6LJEB/27 monitor PSU, board number 715G6457-P01-000-0010.
        Data:
        - Schematic is attached to post
        - Photos can be found on flicker: https://www.flickr.com/photos/198547898@N03
        Problem:
        - PSU board have power outputs at 5.2V, 12V and 24V - board is correctly outputting only 5.2V (correct), and not 12V (without load only 8.16V) or 24V (without load 0V)
        State of PCB / monitor:
        - Bought defect monitor from a company auction
        - There were some attempts to fix...
        06-19-2023, 11:40 PM
