Monitor Audio RSW-12 Schematics
  • bmor
    • Jan 2020
    • 18
    Hi, I've been working on this subwoofer and got these from MA. Thought I would post them here in case anyone is interested. They told me there is no service manual.
  • peterem74
    • May 2022
    • Hungary
    Re: Monitor Audio RSW-12 Schematics
    Thank's schematics
    • moan8452
      • Aug 2022
      • Denmark
      Hi bmor
      Do You have an address where You got the rsw12 schematics.
      I need a set for rxw12
      • bmor
        • Jan 2020
        • 18
        This is the email for the office in the UK: technical@monitoraudio.group
        • OgrusKornel
          • Dec 2022
          • United Kingdom
          Thank for the Schems! You save my sub
          • bmor
            • Jan 2020
            • 18
            �� These subs are too nice to not try and fix them.
            • marekshome
              • May 2012
              • Latvian
              Thanks wery good help me this info...)
              • r4dk01
                • Jan 2023
                • Slovenia
                Thank you for the schematics!
                • tommyw
                  • Feb 2023
                  • usa
                  Thankyou for the schematics. That will make this fix a breeze. tommyw
                  • old_marantz
                    • Aug 2023
                    • 7
                    Can someone help me with this?
                    I got a new subwoofer amp from Monitor Audio to replace a broken one.
                    The new amp haa 12 hole molex ribbon cable that is suppose to go to the control board on top of the subwoofer (gray cable with black connector see pic). The existing control switch on the top of the subwoofer has a 8 pin connection (white connector see pic).
                    Since the wiring diagrams are attached to this post, can someone help me convert this 12 hole/wire molex to 8 pin? All these Monitor Audio Control switch are the same. So, most likely 4 of the connection on the gray ribbon cable arent used.
                    If anyone knows how to align this up or knows of a gender bender that might work, I'd owe you beers.
                    • old_marantz
                      • Aug 2023
                      • 7
                      Would the below be the schematic for the control board?
                      • R_J
                        • 9624
                        If this is a new amp from Monitor Audio, why not ask them why it has the wrong plug? Might be safer then connecting it up wrong and damaging something.
                        • dobrykamil
                          • Jun 2013
                          • 63
                          You most likely have been sent wrong back plate mate.
                          • waryan
                            • Jul 2024
                            I was just offered this sub at a great price, but it blows fuses on power up. Any ideas on where to start? Assuming I should begin measuring on the AC Board and go from there. Thank you.
                            • Alan449
                              • Aug 2024
                              • United Kingdom
                              Hi After a little help with a component identification on my Monitor Audio Silver W12, it is fitted with a UcD400MP amp board. It no longer powers up, after dismantling the amp I can see a blown component on the mains input, unfortunately it is damaged to much to get any identification details, hoping someone here can help, I have attached a few pictures of the board. Any help or advice welcomed.
                              • R_J
                                • 9624
                                It is likely a NTC Inrush Current Limiting NTC Thermistor, the board lists it as R5 if you can get a rough idea of its diameter the cold resistance is likely around 5Ω
                                See if there are any numbers left on the other side
                                Maybe a Bourns BN-LG15Y5R0Mx or ant similar NTC 5D-15
                                • Alan449
                                  • Aug 2024
                                  • United Kingdom
                                  Thanks for that RJ, its roughly 13mm in diameter, no markings left at all unfortunately. have ordered a couple of 5 ohm 13mm ones, will give it a go and see if anything else is damaged.
                                  • MOSSEP
                                    Monitor Audio RSW12 - Green light but no audio
                                    by MOSSEP
                                    Hi
                                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                    I have already tried replacing all of the...
                                    01-26-2025, 08:18 AM
                                  • MOSSEP
                                    Monitor Audio RSW12 - Green light, but no sound
                                    by MOSSEP
                                    Hi
                                    01-26-2025, 08:33 AM
                                  • samson7point1@yahoo.com
                                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                    by samson7point1@yahoo.com
                                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                    The player processes the audio signal using two different reference frequencies. The "R"...
                                    04-30-2024, 11:22 AM
                                  • keepread
                                    Dell monitor PSU vs Dell laptop PSU
                                    by keepread
                                    Hi there!
                                    Someone gave me their old monitor, it's Dell S2715ht.
                                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                    10-30-2025, 04:45 PM
                                  • Delicieuxz
                                    I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                    by Delicieuxz
                                    I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                    Here's an audio clip of the sound coming from my speakers:
                                    https://vocaroo.com/16HaryHwTx78
                                    I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                    11-15-2023, 09:50 PM
