Pioneer VSX-3300 Receiver Wont Power On
  • budwich
    • Jul 2015
    • 3097
    Re: Pioneer VSX-3300 Receiver Wont Power On
    Not sure how easy it is to get at c617, but that would still be my guess based on your posts. Its a 5.5v which might be pushed if there was any issue with the 5v lines.
    not sure what the 5vbu serves .... does the unit turn on with it disconnected?
    • thetonywarren
      • Feb 2013
      • 168
      It's a complete pain in the butt, but I did get it out and took it out of circuit. I have a basic meter to test it, but it doesnt go high enough to test.....this one is rated at 47mF 5.5v. My cheap capacitance meter only goes up to 20mF......
      Any suggestions??
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        Disconnect part of the 5Vbu, I d would like to see that the microprocessor still works. The 5Vbu splits, feeds the microprocessor on end and goes to the 100ohm resistor and a capacitor C617 in series on the other board. So lift that 100 ohm resistor and turn the unit on and see if the voltage stays. If C617 is bad, it will sour your day too. Follow the line a bit further down and you get to the Power Transformer and a fuse, check it.
        I might have a bad feeling that the microprocessor is bad. If there would be a lot of current drawn from the other board, that 100ohm resistor should be toasty warm.
        • budwich
          • Jul 2015
          • 3097
          IF you disconnect the resistor in question, you can again do the simple resistance check towards the rest of the circuit (microprocessor) just like did previously and see what it gives you there in. That might tell you something about the processor electrically.... maybe.
          • thetonywarren
            • Feb 2013
            • 168
            Ok, so I re-soldered in the information screen/panel re-soldered in C617, re-soldered in C706 and then I removed one leg of the 100 ohm resistor at R613.
            after I did that, I pressed the power button and it turns on.....hopefully this gives us a better idea of what's going on.....
            Thanks!!!
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              That means the microprocessor is ok and the problem is below the 100 Ohm resistor. Did you check C617 to see if it is still good?
              Actually take some voltage measurements at the microprocessor.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                It’s gotta be that c617 cap. It goes to gnd. Change it and see what happens.
                • thetonywarren
                  • Feb 2013
                  • 168
                  I have one of the cheap multi-function testers and you can see what shows on the screen, looks like it's testing at 34mF, seems low to me, but not sure with this size of cap.....when I look for replacments, I dont see any of similar size, all I can find are supercaps? Is that what this one acutally is, they seem to have different physical sizes than the one I have here.......
                  • budwich
                    • Jul 2015
                    • 3097
                    good work... size isn't necessarily an issue except maybe fitting to the board / mount. You might have to do some mod (ie. jumpering, glue, etc). look for something with the same capacitance and move up in voltage... it will likely be smaller physically (also due to advances in technology).
                    • thetonywarren
                      • Feb 2013
                      • 168
                      This is what I purchased.....see attached screengrab.....I couldnt find a suitable substitute with a higher voltage rating, so hopefully this one should do......
                      • budwich
                        • Jul 2015
                        • 3097
                        hmmm... might not work. I don't see that it is an electrolytic (ie. polarized) which I believe the c617 is. You need to check that.
                        • R_J
                          • Jun 2012
                          • 9588
                          That cap is likely bad, it is a super cap 47mf/5.5v, mille not micro farad used for backup. It is possible the cap has been discharged for so long it won't charge any more and loads the 5v line too much so the micro won't turn on.
                          You don't need to have a higher voltage cap in that position 5.5v is what it should be.
                          • thetonywarren
                            • Feb 2013
                            • 168
                            Check page 2, and page 7, I think it is polarized, at least from what I can find......Hopefully I picked an ok one, cause I couldnt find any close equivalent on the electrolytic side of selection on DigiKey.......
                            • R_J
                              • Jun 2012
                              • 9588
                              Yes it is a polarized capacitor it acts like a backup battery in the circuit.
                              • thetonywarren
                                • Feb 2013
                                • 168
                                ok, so I then think that the one I purchased is ok...... Now to wait for parts to arrive, man, I wish there were local places to get stuff like this......
                                • R_J
                                  • Jun 2012
                                  • 9588
                                  This component is a bit rare these days, most equipment uses other ways to backup settings etc.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    This is like Xbox, pre-360.
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      That super cap is not really needed for function. It’s probably just to keep settings, time etc. With the super cap c617 removed, the 100 ohm resistor put back in place, the unit should work now fine. Looks like the old cap is “wet” on the bottom?
                                      • thetonywarren
                                        • Feb 2013
                                        • 168
                                        What do you actually mean when you say the cap is "wet" on the bottom, Im not familiar with that term.....
                                        Thanks for the help!
                                        • petehall347
                                          • Jan 2015
                                          • 4439
                                          #60
                                          has it got a leaky bottom ?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
