1973 Magnavox. One dead channel.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: 1973 Magnavox. One dead channel.
    Now, does the amplifier work properly once more...
    • JunkForLess
      • Nov 2021
      • 44
      Well... it kind of worked. I noticed the right channel was kind of there now, not 100% dead like before. I pushed down on the volume knob a bit and the right channel came around loud. A month ago, before I took this thing apart, I sprayed all the pots with D5. I know for SURE this wasn't the case before, but I don't think I would have been able to tell since the right channel was 100% dead. Its kind of like a double stacked pot. The pot nearest the knob is the right channel, I was brave enough to take that half apart and found it to be really dirty. Soaking it a bit to clean the left channel.
      TA DA....
      Uh oh...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        well, how does it sound, and did you pull the 22 ohm resistors?
        If you're fine with how it sounds (make sure you also check music with the volume down low), then don't bother pulling the 22 ohm resistors. it'll keep the transistors cooler at the expense of distortion.
        • JunkForLess
          • Nov 2021
          • 44
          I need to step away for the night. Even after cleaning the volume pot I still need to screw around with the volume knob to keep the right channel working. Sometimes you have to press it a bit to one side, or pull up a bit.. I don't believe there is anything I could replace it with since it has all the extra taps?
          When working, everything sounds great. The thing can get pretty dang loud, so I would be up for ideas on how to replace it even if I have to give up the top half of the volume range.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Looks like a very custom and log pot. Main problem is that it's a PCB mount it seems? I guess you'll need to do what you need to do. Great that it sort of works now, but any qualitative information about it, including how the left channel sounded prior to the change (the right channel probably sounds infinitely better than before, of course)?
            I find my ears get annoyed when in a closed room near a stereo with only 2 watts of power per channel. I'm sure at 20WPC they'd hurt. I've never tried pumping my Denon up to its rated 70WPC, then again I don't have enough speaker(s) for it to probably shake down my house...
            Incidentally I was doing some calculations and that Denon's quiescent power draw is immense due to the bias needed... IIRC like 60+ watts when quiet, and it doesn't help with 5 channels...
            • JunkForLess
              • Nov 2021
              • 44
              Left channel is just as strong as before. Right is very strong when the loudness pot isn't causing it to kick out
              Can I skip the stuff tied in at 150,151 and 152,153 and just tie in a audio pot? The pot also bolts onto the front, so I could put another pot in there and rotate it so the pins face up, then wire it to the PCB however I wish.
              For example:
              PC3b pin 1 > pot > point 93
              PC3a pin 7 > pot > point 112
              What does all the stuff in PC3b and PC3a seem to do?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                Based on your replies it "sounds" you're not an audiophile either and don't care how it sounds as long as it's somewhat close, like me... so in this case yeah you can probably just not connect the stuff hooked up to the taps. The taps try to emphasize certain parts of the spectrum at different volumes so without then, likely things will sound different and you may need to do the same to the left channel to make things sound balanced.
                Again IANaA.
                • JunkForLess
                  • Nov 2021
                  • 44
                  Again IANaA.
                  100% correct, I just want to play some Christmas records and maybe some Dean Martin . It will most likely live most of it's life at mid-low volume, I don't mind adjusting the knobs to get the sound right.
                  What factors do I need to look out for with pot sizes? For example, if the pot doesn't have a high enough range would that mean I wouldn't be able to mute it? The face of the radio doesn't have any sort of volume scale printed on it, so I don't mind if "max" comes before a full turn. EDIT: I am a noob, now that I study the diagram a bit more, the 10K and 50K values are for the taps (won't be used), the pot range I need appears to be a 100K, two gang, audio, correct? Eying up 652-PDB182-B230K104A.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    If the slider can be adjusted to 0 ohms to GND then it will mute just fine, but again the sound and behavior of the knob will likely be different as you adjust it through the range. Chances are what used to be 50% will be something else.
                    I also would think as you're going to be omitting the PC3 circuitry that 100K may now be too high and the lower part of the taper might not produce enough volume change. But this is just a guess based on the circuitry...
                    • JunkForLess
                      • Nov 2021
                      • 44
                      Got it, I have a few cheap ones laying around, I'll try a few values first.
                      I freaked out a bit when I saw how crazy the stock pot was, I thought I was stuck after all this work. The old non-tube stereo consoles aren't worth much of anything, but I wanted to get it working. I need to practice on this cheap stuff first.
                      Think I should remove PC3? I wonder if it will do anything odd left floating.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8711
                        no idea what else is on PC3...
                        • JunkForLess
                          • Nov 2021
                          • 44
                          It only has what is outlined in both. So, 7 total pins, 1,2,3,4 for the left channel 4,5,6,7 for the right channel, pin 4 is a shared ground pin.
                          Either way, it was easy to remove so I left it out for now. I hooked up the 100K pot up and it doesn't work. Tried it on left and right. To make it even harder, it seems the diagram doesn't match the board 100%. My best bet might be to draw out the physical board and confirm I am not blind.
                          • JunkForLess
                            • Nov 2021
                            • 44
                            Best I can tell, the bass section of the diagram is correct, but it's placed in the wrong order. The correct order is Timbre, Treble, Bass, Loudness. So I don't feel as crazy now.
                            • JunkForLess
                              • Nov 2021
                              • 44
                              Great news:
                              With PC3 removed, the factory pot works. It's still only a single channel, but that confirmed that PC3 does something that I might not even care about.
                              Using jumper wires, I connected the factory pot in like a standard three lug pot (works like a 100k pot) No extra taps. It works as it should and I moved it between the two channels.
                              When I posted the other night saying it didn't work, I had it wired it the same way except I was using a cheap pot I had laying around. Something that most likely came in a Arduino hardware kit.
                              Forgive the messy work:
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8711
                                Oh...it's a hybrid...
                                • JunkForLess
                                  • Nov 2021
                                  • 44
                                  The parts show up tomorrow
                                  • JunkForLess
                                    • Nov 2021
                                    • 44
                                    So, it was working PERFECT... then I removed it from the cabinet to clean up a few things and noticed the right channel was a bit odd again.
                                    This is starting to come together like a CSI episode...
                                    I believe there might be a bad solder joint between the back panel board and the main board. The speaker output passes through that board first, along with a bunch of BS, then comes back down. If you lightly press on that board the channel comes back. The volume knob is located on the edge of the main board and that rear board.. I bet the last owner(s) fix was to apply pressure to that volume pot (like I did) and make it work for a bit. Over years It wore out the bushing and then messed up the carbon trace... Also, I am sure it spent a lot of time with that channel open, causing it to blow out the transistors..
                                    I am going to re-flow the joints between the board. If that fails, I will just bypass that whole section. It's function is for the 2-Channel/4-Channel switch and 4 channel decoder. It also has the External speaker lugs.
                                    In the attachment below, on the left side, 123 and 127 ish are the output caps. I really don't care about the stuff in the middle. I would tie the speakers in at 123/127, call it good.
                                    • JunkForLess
                                      • Nov 2021
                                      • 44
                                      Well well well.. got her running perfect now. See attached.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8711
                                        hooray for broken solder joints...
                                        • JunkForLess
                                          • Nov 2021
                                          • 44
                                          Thanks a lot for all your help. Learned a bunch. I'll be making a demo video of the console soon.
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • mikey5791
                                            Help on car amplifier only one channel works
                                            by mikey5791
                                            Hi all forum members,
                                            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                            08-06-2025, 10:36 PM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • dicky96
                                            American Audio VLP1500 Distorting on one channel
                                            by dicky96
                                            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                            Protection and Clip LED are off
                                            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                            07-13-2022, 05:25 AM
