Mitsumi M32E-3 CD tray motor
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I'm trying to repair a Kenwood DP-320 CD player. The tray motor is open circuit so I need to find a replacement.
    The motor is a Mitsumi M32E-3. From a UK perspective is there a equivalent that will do the job?
    Many thanks.
    • 31218
    Re: Mitsumi M32E-3 CD tray motor
    post a picture.
    • R_J
      • 9594
      It doesn't look like it is available any more, I did see used ones on the internet but they are used and could be ready to fail. There are likely replacements available or check with a local service shop, they might have one.
      • R_J
        • 9594
        Is there a R-14xxxx number on the motor? there are specs for M33E-3 series but might not be the same. Do you know if it is a 6v or 12v? On similar kenwood cd players the drive voltage is 9v
        You will need a motor without speed control because it is reversible CW & CCW
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          The full number is laid out like this:
          Mitsumi M32E-3
          CW + CCW R-145767
          1640264 2198DA
            • 31218
            you may be able to just rip a motor from an old pc cd-rom drive.
            that's why i asked for a picture.
            it's not like they have regulated speed or anything.
            you just need the screws in the right place and the shaft the right length
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              ...now searching the loft space for an old CD/DVD drive...
              • Agent24
                I see dead caps
                • Oct 2007
                • 5041
                • New Zealand
                There are many such small DC motors available on AliExpress etc. How long they last is a different story, but you may well find one that can fit.
                Again, it would help to see a photo of the original/some measurements.
                -David VanHorn
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  Sorry for the delay. Here are some pictures of the motor.
                  Without measuring them, I'd guess the threaded screw holes are M3
                  • petehall347
                    • Jan 2015
                    • 4440
                    • United Kingdom
                    looks like a pretty standard motor . you want want that can go both ways . i cant imagine your one is actually worn out .might just need cleaning inside .. take it you have tested it ?
                    • R_J
                      • 9594
                      It does seem odd that it's bad as it is just for the tray, hook a 9v battery to it and give it a spin, if it runs, run it for a while to clean the brushes. The screws will likely be M2.6 x 0.45
                      • Nevillet
                        • Sep 2019
                        • 272
                        • United Kingdom
                        I've powered the motor directly from a bench supply (i've gone up to 12V) and spun the spindle but it does not rotate under power. The spindle does spin freely with finger pressure.
                          • 31218
                          if you open it for "science" dont expect to get it together again.
                          getting the brushes onto the commutator is a bitch!
                          i learned that trying to cheap-out on central locking motor repairs!!
                          • Nevillet
                            • Sep 2019
                            • 272
                            • United Kingdom
                            Ive never been able to reassemble a small brushed motor like this.
                            • R_J
                              • 9594
                              On this type of motor you need to assemble the brush end to the armature then slide it into the motor housing. its a pain but should work.
                              On some motors (like the other one in the picture) there are holes in the plate to insert pins to hold the brushes away from the commutator as you reassemble it, then you remove the pins and the brushes snap into place.
                              • juergenb
                                Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                by juergenb
                                i am asking for some Help.
                                I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                So i got a few of these from Banggood.
                                I swapped the motor and now i have a new fault condition.
                                In a working Frother you would press the start button, it will light red and work for a few minutes.
                                If you press longer it will light blue and just mixup the milk.
                                With the new Motor it just starts...
                                03-23-2021, 11:24 AM
                              • sbt123
                                charnwood w821 mini wood lathe motor problem
                                by sbt123
                                hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                10-27-2024, 03:43 AM
                              • DrDos
                                Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                by DrDos
                                Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                08-08-2025, 03:16 AM
                              • mikey5791
                                Help identify this motor
                                by mikey5791
                                Hi all forum members,
                                Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                Correct me if i am wrong on the initial test.
                                Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                11-24-2023, 07:54 PM
                              • Per Hansson
                                Motor run capacitor physical size vs voltage rating & measurements?
                                by Per Hansson
                                (TL;DR skip the first paragraph)
                                I encountered my first dead motor run capacitor at a customer this week.
                                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                (Unless a servo motor makes more sense that is).
                                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                The pump would run but sometimes trip the 10A breaker.
                                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                Then it could...
                                09-20-2020, 06:32 AM
