Numark NS6 Usb problem
  • falcontech
    • Oct 2013
    • 470
    • italy
    Re: Problema Di Numark NS6 Usb
    Originally posted by stj
    if you had the programmer, you could try talking to the atmel to see if it's dead or not.
    could I do it through the program you indicated to me before?
      • 31013
      Re: Numark NS6 Usb problem
      yes,
      you can ask the chip for it's ID(part number) and if it's not protected then you can read out the code memory's(it has 2) and the option-bytes
      • falcontech
        • Oct 2013
        • 470
        • italy
        is there a guide on youtube for how to do it?
        • falcontech
          • Oct 2013
          • 470
          • italy
          I have buyed this
          https://www.informaticait.it/arduino...o-e-adattatore
            • 31013
            o.k.
            here is a usefull link
            http://ladyada.net/learn/avr/avrdude.html
            and downloads
            http://download.savannah.gnu.org/rel....3-mingw32.zip
            https://cdn.badcaps-static.com/pdfs/...0e8896b305.pdf
            there are other usefull links i'm sure others will provide that relate to wondows drivers
            • falcontech
              • Oct 2013
              • 470
              • italy
              #26
              I found this, it seems the same but without the use for the command prompt, just install it, sorry I'm looking for a shortcut but for the first time I use this programmer and I would like to make things easier
              https://blog.zakkemble.net/avrdudess-a-gui-for-avrdude/
                • 31013
                no, that's good.
                i'm a command-line / Linux type of person so i was hoping someone else would link dudess and the zadig driver installer
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #28
                  Sorry but I don't understand, is it okay or not okay for what I have to do?
                    • 31013
                    it's o.k.
                    this is the driver installer
                    https://zadig.akeo.ie/
                    • falcontech
                      • Oct 2013
                      • 470
                      • italy
                      #30
                      Thanks, surely I will need you as soon as the programmer arrives, in the meantime I have written to numark to send the firmware let's see if they are good
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #31
                        yes,
                        Based on the image, could you tell me what the settings are for doing the atmega162 function test?
                          • 31013
                          you would set the "programmer" to usb-asp,
                          then select the "detect" button on the right i think.
                          • falcontech
                            • Oct 2013
                            • 470
                            • italy
                            #33
                            184/5000
                            I would also like to understand if I have to power the card where the ATM is located or there is no need, and how can I understand the polarity of the isp connector, I would not want to do any further damage
                              • 31013
                              good questions.
                              the programmer can supply power *if* the connector on the numark uses that pin.
                              getting the connector the right way,well this should help
                              • falcontech
                                • Oct 2013
                                • 470
                                • italy
                                #35
                                This is the error message when I try to test the chip, but from the same message even without a cable connected, I tried powering the card and without power if someone could tell me where I am wrong I will be grateful to him, or simply the chip is dead and there is no response
                                  • 31013
                                  i think the chip is dead.
                                  i'll try it myself later without a chip to compare error messages
                                  • falcontech
                                    • Oct 2013
                                    • 470
                                    • italy
                                    #37
                                    Ok thanks
                                    • falcontech
                                      • Oct 2013
                                      • 470
                                      • italy
                                      #38
                                      Hello
                                      Any news?
                                        • 31013
                                        tonight will try - i'm just waiting for a customer to pick stuff up this afternoon.
                                          • 31013
                                          confirmed,
                                          that message is what you get if it cant see the chip / the chip is not responding
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • foshland
                                            DELL XPS 9560 Burned zone need photo please
                                            by foshland
                                            Hi to all, I have a XPS 9560 with some faults, im working on it for fun, I have a "burned" zone I need to dremel but afterwards ill need a photo of the zone for rebuilding as far as I can, I have the schematics and the boardview but will like a photo, if some of you can get any so I see the traces will be cool.
                                            It was some kind of lucky that the zone had not too much components, so I think I can deal with it.
                                            Its under the zone where PC308 PC309 and PC337 is located, next to PU300
                                            Thanks a lot for all and "pray" for me ...
                                            04-21-2022, 07:33 PM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
