Broken Condenser Microphone MXL CR89
  • Shepa
    • Apr 2020
    • 3
    • Japan
    Hi! I've got a broken mic. Do not know its history.
    After connecting to phantom power and preamp it works for 30-60 seconds and then the autoexcitation starts. It begins to buzz lightly and then I can hear strong buzz only.
    I could not find schematics for MXL 890, V89 or CR89 which supposed to be the same.
    The circuit board looks fine except one 47 Ohm resistor, which looks burned.
    Should I change this resistor only, or capacitors and op-amps could be damaged as well? Unfortunately, all op-amps names were scratched away by the manufacturer.
    Thanks!
  • R_J
    • 9535
    Re: Broken Condenser Microphone MXL CR89
    Get some freeze spray and freeze the components to find which is causing the issue, I could not find the 47Ω you are refering to, What is its location number?
    U3 might be a 4562 op amp, try wetting the top os the ic, maybe part of the number will show up.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Looks like, as RecordingHacks mentions, the CR89 may well be a revision / new paint-job of the V89. Which would explain the "deleted" model number on the silkscreen - "MXL [something else] REV NC".
      http://cdn.recordinghacks.com/images...89_circuit.jpg
      Physically smaller ceramic capacitors this time around, but looks like the exact same circuit / board.
      I'm 95% sure the two 14-pin SOICs are likely something like 40106 hex Schmitt trigger inverters - all the ceramics and the diodes underneith them point towards that.
      https://i.pinimg.com/originals/cc/6b...0e8130c171.jpg
      The circuit looks like a twist on the old Schoeps circuit - JFET input as a high-impedance buffer and phase-splitter, and instead of a pair of PNP's, they used that dual opamp to drive the output.
      https://billthompson.us/bt/sch/cmc5-schematic.jpg
      The two huge electrolytics (Nichicon Muse? eyeroll...) block the phantom-power DC from affecting the opamp's output. Tough to tell with those in the way, but at least one (if not both) of the 40106's are for supplying the opamp, i think. The other, likely to provide the bias voltage to the capsule.
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • redwire
        • 3906
        Post a pic of the other side of the PCB, with the burnt resistor.
        It's a typical condenser microphone design.
        U1, U2 are the voltage multiplier for the capsule bias voltage, usually +/-60VDC. Guessing CD40106B
        U3 is just a buffer with number looking like LM4562 as others have mentioned.
        • Shepa
          • Apr 2020
          • 3
          • Japan
          Thank you!
          In this photo one of the blue-green resistors has a black ring as well. It means that it is not the burning mark. I thought they should look the same.
          Yes, the two huge electrolytes are Nichicon KZ Muse 100uF 50V.
          On the other side, two Nichicon KW(M) 10uF 50V around J-FET 2SK170-GR.
          And on the exit Nichicon PW(M) 150uF 50V.
          Maybe I will start with replacing capacitors.
          Thank you for naming IC's !!!
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Not too sure the capacitors are the issue. "For audio" or not, Nichicon should be one of the very few really dependable brands, and since phantom-power is fed through a pair of 6.8k resistors, they couldn't have had a hard life at all.
            And speaking of phantom power - even if you short both signal lines to ground, you'll get a max of around 14mA, all of which gets "burned up" in those two 6.8k resistors that are inside the preamp (that the mic is connected to). So there's technically and physically no way anything can "burn" in a phantom-powered mic like this. Unless something went VERY wrong with the preamp, but that's a different story.
            Might i suggest starting with probing for some voltages first, before "shotgunning" with the cap replacement?
            Those "blue green resistors" are actually a pair of 47uH inductors, in series with the outputs.
            • redwire
              • 3906
              Originally posted by Khron
              ...And speaking of phantom power - even if you short both signal lines to ground, you'll get a max of around 14mA, all of which gets "burned up" in those two 6.8k resistors that are inside the preamp (that the mic is connected to)...
              If you short to GND a mic preamp input, there is a high current discharge.
              For the repairs I have done, I find the signal coupling capacitors in the mic pre-amp/mixer (end) are charged to 48VDC and will hit a microphone's electronics hard if plugged in hot.
              This can damage the mic's clamp diodes or other parts going to the XLR. But not burn up anything, as you say.
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
              • ArchangelGabriel
                Aorus 17G YD laptop, broken display, could not switch to external monitor
                by ArchangelGabriel
                Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                11-23-2023, 03:55 AM
              • corrize
                Resonator - quartz broken - how to find the same (same frequency) ?
                by corrize
                Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
                I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
                I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
                I'm searching another one for compare…
                Do you have an idea or another way for find the frequency of this resonator please ?
                (I did not found the manufacturer of this component ? And I did not found the...
                03-27-2025, 09:20 PM
              • emeskay
                Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                by emeskay
                We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                08-06-2024, 07:13 AM
              • chth96
                How can I test coil whether it is really broken or not?
                by chth96
                I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                I want to replace this round black fuse and unidentified coil if it got broken.
                02-20-2024, 01:07 AM
