Crown Amp DC300A - One channel distirted, other good.
  • budwich
    • Jul 2015
    • 3097
    I am the original owner of this DC300A. It drives some JBL cabinet speakers but doesn't get used much in the last 25 years... maybe playing an hour or two every year. :-(
    Anyways, went to give it a run and one channel is distorted while the other is clean / clear. Tested the cabling to the speaker and did a swap test and the problem stayed with the channel. Check the cabling to the crown IC150 pre amp, along with a swap and the problem stayed with the same side.... so the amp channel channel appears to be the problem.
    I don't know much / anything about audio amps other than basic electronics type level measurements, etc along with general setup.
    Started taking it apart. Attached is the layout of the boards with the front panel removed and main control board "loosely mounted".
    Because the one channel works and other is distorted, I started checking all the resistor / capacitors (resistance reading) and comparing across sides of the output boards. The only significant difference that I could find was a resistance difference on a capacitor across the output terminals. On the good side, it reads resistively as 2.96k while on the bad side, it reads 3.97k. Its a .1 MF 200v Filmatic ITW. I don't have an ESR meter, just a regular DVM.
    I know that a resistance measurement of capacitor doesn't have much meaning / use but is that difference enough to indicate a bad cap. In "amp land", I don't even know what the purpose of the cap is going across the output terminals.... getting rid of high frequency noise?
    Any guidance on this thing would be greatly appreciated as I would love to get it working again as it deserves a better fate.
  • petehall347
    • Jan 2015
    • 4445
    Re: Crown Amp DC300A - One channel distirted, other good.
    clean the switches and contacts first .
    • budwich
      • Jul 2015
      • 3097
      can try.... but there is only a power switch (can't cause a problem to only one channel) and two volume / gain pots which don't cause any "crackle" when turned. Will look closer at the two output terminals.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5081
        • New Zealand
        Could be a transistor problem, leaky, shorted, missing power rail. Might be better to do symmetrical voltage measurements across channels.
        Check for DC offset at outputs first I'm thinking. Shouldn't be more than a few milivolts.
        -David VanHorn
        • budwich
          • Jul 2015
          • 3097
          thanks... will give it a try. Probably can't see much "offset" with just a meter, at least I can check if DC rails are there / "close". I have to figure out how to safely power up and still get access to various points (boards have no labeling).
          • Agent24
            I see dead caps
            • Oct 2007
            • 5081
            • New Zealand
            You could do diode/resistance tests on all the semiconductors without power on. If something's shorted it will show up.
            -David VanHorn
            • budwich
              • Jul 2015
              • 3097
              yes indeed, that was going to be my next "non-power test". I need to look at the board to see exactly what is connected to where... with no marking / labels its a bit harder to figure out what an inexperience eye sees. Once I figure that out, those checks should be good, assuming an in board test of the component won't impact the result... again given that one side is working, the comparison results hopefully will point at a "yeah" or "neah".
              • budwich
                • Jul 2015
                • 3097
                Well... I didn't electrocute myself yet... :-)
                Anyway, was able to power the unit up with the main board demounted so the access to the other boards is possible. Measured the two "rails" for each side. Basically, they were each about 61.75 / -61.75v (with some "drift"... up to .8) "unloaded" (ie. nothing connected to the input or output terminals). The nominal voltage for the rails is 60/-60v.
                It would appear that the rails are good.
                Doing some diode mode testing on the output boards didn't find any differences between the sides although without demounting the output transistors, it would not be possible to find an open circuit since they are connected in parallel. There were no shorts per se.
                I haven't done any testing on the main board yet. Looks like maybe the problem lies in the "pre section" of the main board for that side possibly although still wondering why such a big difference in the resistance measurement of the capacitor across the output for each side.
                • budwich
                  • Jul 2015
                  • 3097
                  Attached is a schematic that I was able to dig up in my files.
                  One question that I have with respects to the capacitor across the output (c218 by the pen pointer), can I just remove / disconnect it without an operational issue for a brief test?
                  Crown assemblers must use some big soldering irons as everything has large solder points to attach to / heat up (ie. screw ends, terminal lugs, etc).
                  • dom0
                    • May 2019
                    One of the quickest ways of troubleshooting just one bad channel is to feed the amp with the same, say, 1 kHz sine on both channels and then just working from either the inputs or the outputs, checking the signal shape on the good and comparing it to the bad.
                    I usually start from the outputs, because the higher the power, the more often it breaks.
                    Edit: Removing C218 might result in HF oscillation of the amplifier, but it probably won't.
                    • budwich
                      • Jul 2015
                      • 3097
                      I don't have access to a scope at this time. :-( can feed a signal in from a test cd but without the scope, I don't think it will help at this point. Maybe have to call in some "favors". I can certainly see that looking at the output of the main board as it goes to the amp stage would certainly narrow things alot.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5081
                        • New Zealand
                        Without a scope you can use another amplifier (or build one from something like an LM386) as a signal tracer, then follow the signal through until you find where it becomes distorted.
                        This would work great in the preamp/input section just as a plain input.
                        In the power section you will need a voltage divider/clamp on the input to avoid overloading because of the high voltages. A DC blocking capacitor would be good too, in both cases. Make sure it has a rating higher than your main voltage rail value.
                        -David VanHorn
                        • dom0
                          • May 2019
                          I've never tried it, but there is "soundcard scope" software which uses the line in of a laptop / PC. Definitely want a voltage divider + AC coupling capacitor for that one, though!
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5081
                            • New Zealand
                            Yeah, that would probably work great with an appropriate probe. Actually I think EA or SC magazine made a kit to do that with an interface box for various attenuation ranges etc.
                            -David VanHorn
                            • budwich
                              • Jul 2015
                              • 3097
                              interesting ideas /thoughts... thanks. It got me thinking. These suggestions use your ears (hearing the probing results) while a scope uses your eyes to see the results. So then, how about using my DMM meter to "hear" the "probing".... I can just put it on the "freq" range and hopefully it will "hear" the 1khz "tone" and put out a good frequency rate at points on the good side. On the bad side, if the signal is "distorted" (I need to get the title updated... it was a typo... distirted...:-) ) along the circuit path, then hopefully the meter will either put out some other rate or have problems "locking" on a frequency and "roll" or otherwise. May be it will work almost as good as hearing / seeing the test with my eyes / ears. Fingers crossed.
                              One question though... where in the circuit do I need to "probe".... the input to the bases of the output transistors or at the emitters?
                              • budwich
                                • Jul 2015
                                • 3097
                                thanks for the warning on the capacitor... I think I will try the "dmm in frequency mode" to see if I can at least isolate whether the problem is at the main board or at the output / amp board.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  oops.... I needed to pay more heed to this. :-(
                                  I was "playing" with the "DDM frequency mode"... and bad things happened when I probed from red on one of the emitter incoming lines (from the main board to amp) with black on the chassis ground.... large noise immediately...scared me and blew the fuse on the lead to the speaker.
                                  I was expecting some sort of DC block in the meter or otherwise. Need to go back to the drawing boards and think on this a bit. I certainly don't understand how the circuit works and what to expect where.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5081
                                    • New Zealand
                                    The frequency input in your DMM likely only works at TTL logic levels, e.g. 5v. Check the manual to be sure.
                                    Probably wouldn't work anyway, even if the 1kHz tone gets distorted, it'll still be at 1kHz.
                                    The best option in your case is likely an audio signal tracer using sound card or other amplifier. Unless you can borrow a scope.
                                    -David VanHorn
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      I have to investigate the meter but I am sure that I have used it to check the incoming AC frequency on a few house circuits... but the mind does play tricks. Anyway, will push towards the scope.... won't be the first time. :-)
                                      • petehall347
                                        • Jan 2015
                                        • 4445
                                        you should use a blocking capacitor on the positive probe to measure AC .also if you use an audio tracer such as headphones . 0.1uf or thereabouts if i remember right
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
                                        • sima112
                                          Marantz pm 6005 right channel not worknig
                                          by sima112
                                          Hi guys,
                                          I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                          01-30-2023, 12:11 PM
                                        • Logistics
                                          Supermicro X10DAX and Quad Channel
                                          by Logistics
                                          So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                          09-10-2023, 05:12 PM
