Crown Amp DC300A - One channel distirted, other good.
  • petehall347
    • Jan 2015
    • 4426
    #121
    Re: Crown Amp DC300A - One channel distirted, other good.
    i am only guessing it will be ok because it has a miller cap in circuit to prevent high frequency oscillation . all you can do is try or get the right transistor .
    • budwich
      • Jul 2015
      • 3097
      OK... I haven't found where I picked up the bc639 as a plausible replacement... some where in my earlier travels thru forums a while back where some one was trying to revive / rework an old unit. I am hoping that I can remove 2n3859 without any damage (leads have been folded on the circuit board backside during soldering which gives me trouble some times for a clean "pull"). If I am lucky, I will measure the thing on a checker to see what it looks like.
      One thing which I found while probing around with a meter (voltage measurement) with no audio input but gain turned up to hear the noise at bit, I could cause a audible change, slight increase in noise level at various points around the circuit which seems to indicate some sort of ground / common "issue".... or maybe just the noise floor fluctuating.
      • budwich
        • Jul 2015
        • 3097
        I pulled the 2n3859, hopefully without destroying its characteristics. I put in the tester and it shows an hfe 487 which seems rather high along with a 4.4 ma Ic current. I am not sure whether the high hfe was the intent of the "select" (ie. get one as high as possible) or that is the reason it is having a problem... not sure how hfe "ages" / fails.
        I haven't dropped in the bc639 yet... mostly on fear that something bad will happen.
        • budwich
          • Jul 2015
          • 3097
          Soldered in the bc639. Nothing changed, perhaps even a bit louder buzz. Put back the 2n3859 for now.
          • budwich
            • Jul 2015
            • 3097
            with a 1khz tone input, looked at channel one. Maybe hard to see but it shows about a 1v DC level out. The other channel shows a similar output but less DC, ~.25 maybe. I don't know what the "block of pulses", that appear regularly across / over top of the 1khz, are. There are similar ones on the other channel. They are somewhat gain dependent. If I turn the gain to full on, they disappear. Adjusting the gain, intermediately, has somewhat little impact on their magnitude. At full gain and having them not showing, if I push up the input volume, they reappear. I guess some sort of input level dependency somewhere maybe? It appears that the frequency inside the "burst" is about 2.4khz. I would think that it would be audible although maybe my ears ain't that good. Is this the "buzz"? I haven't tried any heating of components to see what the resulting waveform is when the heat appears to improve / remove the buzz, nor have I tried tracing the signal back to see where it originates.
            • petehall347
              • Jan 2015
              • 4426
              #126
              dc is generally clipping . maybe something is being overdriven .is the sinewave clean all the way through the circuit ?
              or it could be leakage i suppose .
              whats the dc offset like at idle no signal ?
              • budwich
                • Jul 2015
                • 3097
                I haven't traced thru the signal to see what things are where yet. The idle dc value on channel one is high at 20mv (channel two is 2mv). When this repair saga started, once "operational", both channels were showing about 2mv. Its possible that some of the changes in components in channel one circuit may have caused a shift but I am thinking that its more likely some component is not functioning correctly still. I still need to check things after a "warm up period" to see if the characteristics change / are measureably improved. That may at least provide some clue (ie. temperature dependent).
                • petehall347
                  • Jan 2015
                  • 4426
                  #128
                  20mv is fine
                  • budwich
                    • Jul 2015
                    • 3097
                    my confusion continues even with simple signal checks along the circuit. I can see a "nice" 1khz at the gain output control going into the opamp. Check the outputs at pins 1 and 13, I don't see any 1khz but I do see the "block of pulses" as seen at the terminal output trace posted.... yet I hear the 1 khz tone plus the lower level "buzz". I am not sure why I can't see any 1khz in the trace at the output, perhaps a level issue or I don't know what I am looking at. The DC values at the opamp out is in line with the SM about 1.4v "nominal", depending on the volume / gain. The +/-10v for the opamp is there although I haven't verify its "condition" (ripple or otherwise).
                    • petehall347
                      • Jan 2015
                      • 4426
                      #130
                      is the idle bias set correctly ?
                      • budwich
                        • Jul 2015
                        • 3097
                        sorry, I am not sure what you are referring to. The output bias at r132 (channel one output board) was around .4v, possibly not yet warmed up but higher than spec. This is similar on channel two (r232). The other resistor (r139... lower "leg") had higher reading of .51v. Again similar on both sides.
                        • petehall347
                          • Jan 2015
                          • 4426
                          #132
                          i will have to check the manual but i think these are set at around 300mv
                          • petehall347
                            • Jan 2015
                            • 4426
                            #133
                            if its same as 300a ii . its set at 340mv across r132 . r139 should be same 340mv
                            r232 r234 for other channel
                            • petehall347
                              • Jan 2015
                              • 4426
                              #134
                              check out 7.3 in the manual and get the bias and offsets set to spec if you can then see how it is .
                              • budwich
                                • Jul 2015
                                • 3097
                                yes those are what I am referring to and yes they do appear to be high. Getting them down might help but it is still somewhat disconcerning about the buzz and the effect of heating a certain area improved that situation.
                                Having said that getting the appropriate resistance to adjust the bias might be a bit tough around here (lockdown, etc). I will see where that leads me.
                                Also still something fishy with the signal trace at the output of the opamp on both channels. So I have a few things to bang my head against. :-) thanks again for your hints.
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  #136
                                  i would go through all the settings then look for any other problems .
                                  offsets and bias first . if input offsets are wrong it might cause a bit of a nuisance .
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    Originally posted by redwire
                                    Crown DC300A Series II schematic, service manual. It looks like yours?
                                    Overall- there's no electrolytics in the signal path, only two in the protection circuit 25uF 15V NP (per ch) and one for 5V DC offset power for both channels C6 100uF, which I would check.
                                    For a quick check if things are reasonable, I would look at +/-10VDC power for the op-amps, check the idling bias current 0.34V across 5.6R driver stage and the op-amp should have around 1.35V at its output.
                                    It's strange to have no bias current trimpot but input offset and output offset trimpots. I think transistors were hand selected and it's a tight design.
                                    This means changing transistors could give bias current (heat) too high or an offset problem. For now, I would just take some voltage measurements to see what is off center.
                                    I am sorry that I never properly replied to your post. I was not aware of the potential significant differences in the various crown dc300a. It appears that my unit is a series I (maybe or series "nothing" as there is no designation anywhere in its user manual or on the unit) and not the series II shown in the service manual that you attached.
                                    Looking further thru this service manual and the one posted in by RJ (post 34), shows a difference in the bias setting checks / adjustment.
                                    I should have paid more attention to the differences and the posts.
                                    Anyway, measuring the voltage across the 5.6 (R132,R139 - channel one, R232, R239 - channel two), they are showing less than .2 v (.14-.18 range). According to the SM (RJ post, section 5.8), the voltage should be in the range of .31-.34, so there is significant difference in the bias on both sides.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Slow progress... really slow. I mis-ordered resistors (low values 1/2 w) for making changes to the bias as per the manual. :-( However, I tried cobbling up a bunch of 15 ohm resistors to give me 60 ohms for channel one (with the warm up buzz). The existing resistor is 82 ohm. The "60 ohm DIY" didn't make any change in the bias voltage that I read but seemed to help a bit with reducing the pre-warm up buzz. I am somewhat worried about how low that I need to go to raise the voltage OR perhaps the manual is "incorrect" with its direct.... " bias voltage low go with a lower value replacement resistor".
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I changed the resistor down to 47ohms (its in series with R128 - 780ohm). It does not make any impact on the bias voltage measured on r132 / r139) which is basically at .14 mv. I am not sure how changing such a limited value in series with 780 ohms is really doing much, but this is way past my understanding of operation.
                                        The warm up "buzz" seems to be less but that might be just today as opposed to anything that I have done. It is quiet with no input connected at any gain setting which seems different. I have to do some scope checks again to see if I see anything different.
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          went "heat hunting" again. I think I found that heating C6 (100uf 16v electrolytic) associated with the 5v "rail" cleaned up some noise in the top half of the 1khz test tone for both sides. This might not be related to the warm up buzz but maybe some form of ground buzz coming thru that cap into the input section and then flowing thru thereafter.
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
