Crown Amp DC300A - One channel distirted, other good.
  • budwich
    • Jul 2015
    • 3097
    Re: Crown Amp DC300A - One channel distirted, other good.
    With the 100w bulb limiter, the two voltage rails on each channel are at +/- 56v as opposed to 60 which seems relatively OK... not full because of the incoming voltage drop from the bulb. Not sure what else to check at this point before removing the limiter. Maybe just praying... :-)
    • budwich
      • Jul 2015
      • 3097
      baby steps forward. Removed the bulb limiter and plugged in directly to power. Unit powers up and the rails are at +/- 61 which is closer to "normal".
      Plugged in a preamp signal which feeds an audio test disc thru to the amp. I have sound.... YES! I need to do more checks to see if there is a channel difference but at "first listen", things seem OK although I haven't really pushed much sound for fear that the thing will go south.
      • petehall347
        • Jan 2015
        • 4444
        #43
        check idle current . measure voltage right across an output emitter resistor
        also check dc offsets at speaker outs
        • budwich
          • Jul 2015
          • 3097
          thanks for this.... not sure about the "dc offsets" measurement but certainly can measure and calculate the resulting current.
          I will add some new stuff. While I was waiting for parts and such, I gathered my "pennies" and picked up a small handheld one channel scope. First use. :-)
          Attached is a picture of the display from the bad channel. The good channel (not posted) shows a "normal sine wave" while the bad channel appears to have lost most of the bottom half. :-( This was at the speaker output. I have not gone further to see where things went bad as the last time I did further "checks" with a meter on the good side, I wasn't careful and took out that channel completely so I am "trigger shy" at this point.
          • budwich
            • Jul 2015
            • 3097
            I measured dc voltage across a few emitter resistors on both channels with no connected input and did not get any voltage reading... ??? The output pots were at some low value.
            read up on the dc offset. measured across the open output speaker connection. Good side was 15mv while the "bad side" was 31mv.
            • petehall347
              • Jan 2015
              • 4444
              #46
              offsets are acceptable .
              does the amp have trimmers for idle current ?
              the scope trace looks like there is a problem with the negative current . check output transistors collector voltage first .then base voltages that should be about 600mv
              • budwich
                • Jul 2015
                • 3097
                not sure about "trimmers for idle current", the only "adjustable board components" are on the main control board (none on either of the output boards) and they are an "input offset pot" and "output offset pot" for each side of the control board.
                The "rails", plus and minus, on both channels are both showing 61.x volts (ie. + and -) accordingly.
                Based on your "hint", I will see if I can carefully track the inputs toward each side to see where the signal get in trouble unless the output stage causes issues all the way back... maybe???
                I am thinking almost that the trace almost looks like a "diode breakdown"... sort of if my recall is correct. There are two "opposing diodes" on the outputs "legs" (going up to each rail). I haven't checked those yet.
                • petehall347
                  • Jan 2015
                  • 4444
                  #48
                  would be worth looking at the drivers voltages . about 1.2v on the bases
                  • budwich
                    • Jul 2015
                    • 3097
                    As you suggested, I checked the voltages associated with the output transistors. On the positive "half" of the output "set", the base emitter voltages appear to be correct (one very low, one high... base versus emitter I think). I then looked at the negative "half set", the base emitter voltages were the same value at basically the -61 volts. :-(
                    correction... on the "positive side" both base and emitter are very low ... on the negative side, both base and emitter are at -61v.
                    disregard this post as I need to pay closer attention to details. :-(
                    • petehall347
                      • Jan 2015
                      • 4444
                      #50
                      each base emitter junction should drop about 600mv . example 1.2v in 600mv out .
                      • budwich
                        • Jul 2015
                        • 3097
                        not sure what happened along the way, but somewhere the signal on the bad channel has gone to a "sawtooth" like wave form while the good channel has remained a nice sine 1khz sine wave.
                        In terms of your recent statement, how are those measured... to what reference point. IF I measure voltage across the base emitter, on the bad channel, I see no voltage (drop) as the voltage is the same on points (taken to chassis ground) where as on the good side, I see a "difference" of about .24 volts.
                        Not sure why the signal has gone to a saw tooth unless something worse happened.
                        • petehall347
                          • Jan 2015
                          • 4444
                          #52
                          i would give that driver board a good looking at with power off . first solder joints then transistors and diodes and resistors . just compare readings from good channel to bad . remove and test again anything that looks bad to your meter .
                          • budwich
                            • Jul 2015
                            • 3097
                            I thought I would give a "signal sniff / scope track" to see if I could find the point where things are going south when compared on both sides. I thought I would look at the signal coming out of the "diff. op amp / ic" with the 1k input. I wasn't able to find the "expected sine wave" on either side.... even though I confirm the expected output at the speaker output jacks. Might be a triggering / level issue. Perhaps also the scope may be causing an issue for the IC although I wouldn't expect it to be so. My ground lead on the probe may be "flaky". I guess the question would be. Should I expect to see the "nice" 1khz sine signal coming out from the IC on each side / channel?
                            • budwich
                              • Jul 2015
                              • 3097
                              I took a closer look at the board layout versus the schematic as the main board has no labeling so transposing where / what component is where is somewhat difficult outside of obvious main components... plus my eyes ain't so good... :-)
                              Anyway, I think I located the points... just after the output of the op amps towards a first transistor (base pin). The "outs" are on pin 13 and 1 of the "dual op ic".
                              Attached is scope shots from each channel.... 1khz feed into the amp.
                              The first is the "good" channel. This shows a reasonably good wave form. Although not shown, the wave form is "superimposed" on top of a 60hz wave form... not sure why or what... maybe some form of hum / grounding issue. The "60 cycle" does not appear in a scope look at the speaker output jacks.
                              The second picture is the waveform come out for the bad channel. Not sure what to make of it other than the frequency is correct but the wave form is "unrecognizeable". The voltage value seems rather high almost like some form of both dc offset plus just plain large signal. I don't believe that the channel gain pot was turned up that high but I need to check.
                              It would appear that perhaps my channel distortion may originate in and around the op amp ic (and supporting circuits) as opposed to the output transistor boards... maybe?
                              • petehall347
                                • Jan 2015
                                • 4444
                                #55
                                dc voltage marked on schematic for pin 1 and 13 .best check them
                                • petehall347
                                  • Jan 2015
                                  • 4444
                                  #56
                                  waveform looks like positive dc on bad one .it should be ac .
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    The +/- 10 volts is there at pins 7 and 14 but I didn't check for any dc value at 1/13 (ie. output) of the op amp. I did a "dry check" (ie. no power) resistance measurement (to ground) on all pins comparing against equivalent at each channel and didn't find any "outstanding" differences.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      perhaps a shorted capacitor somewhere near / the first "leg" off the ic that may not show up with "gross" dc resistance testing... maybe.
                                      Thanks again for the "hints" as my understanding of general electronics is OK but how audio amps actually work / are designed is not really there.
                                      I will do some more voltage checks... my fear is with "live" boards and small distances with shaky hands... :-)
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        With a 1khz input but with volume turn down / off, pin 13 reads 9v dc while pin 1 reads 2mv dc. Does this mean the IC is toast or that some things associated with the output line somewhere is "dead" / shorted (ie. capacitor)? I hope it isn't the op amp ic... not sure if replacements can be had.
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          looking at the schematic and transposing to the board, there is no "R207" ("r107") which are "option resistors" depending on the ic installed. These resistors "tie" the outputs to -10v "legs"... not sure for what reason beyond the viewing the schematic.
                                          To me, this means that there is some for of "leakage" coming thru from the "other 10v rail" linked to the output via Q219 (2n4125)... maybe this is shorted or "turned on"?
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
