Kramer Tavor 5-O powered speakers
  • benV
    • Sep 2011
    • 47
    Hello everbody,
    I have 5 pairs of Kramer Tavor 5-O speakers that have been damaged by overvoltage (thunderstorm). The power seems to be ok. The power led ligths when they are plugged in but no sound at all. I checked the boards but i could'nt find any sign of burning or something like that.
    My question is, what should i check first ? I only have a multimeter.
    Thanks.
    Attached are some pictures of the boards of the powered speaker.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Kramer Tavor 5-O powered speakers
    The physical layout could make it interesting to probe those boards.
    When you say "the power led lights", does it light up green or red?
    In the 4th photo, the little board on the bottom left looks like a small (independent?) flyback supply, that likely handles the stand-by side of things (and turns on the main supply upon signal detection, etc), so if the power LED comes on, either colour, that should still be ok.
    For starters, you could probe the red & yellow wires on that 4-pin connection between the main power supply board and the audio board, to see if that still works. With the big capacitors on the audio board being rated for 35v, i'd expect something anything between +/-20-30v the yellow/red and ground (black wires).
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • benV
      • Sep 2011
      • 47
      Thanks for your help Khron.
      The led lights a solid green on the "On" position and if i put the switch to "Auto", it lights red if there's no input and green if i plug it in my computer audio output.
      About the red & yellow wires between the main boards, here are the results :
      Yellow : - 19,32v
      Black : - 001,3mv
      Black : - 001,3mv
      Red : + 19,08v
      Does that mean that the power supply is ok ?
      What is the purpose of the 3 wires white cable between the audio board an the flyback supply. Is it for the "auto" mode ?
      Can the overvoltage came by the audio input. All those speakers were plugged in computer in classrom but none of those computers where fried. Some others were.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        That sounds 'round-about right then, and yes, the power supply sounds like it's fine.
        That 3-wire connection may well power the signal-detection circuitry, indeed.
        Next you'll want to probe the voltages on pins 4 and 11 of that 14-pin opamp on the audio board - those voltages will be coming out of the two TO-220-cased voltage regulators. I'd expect either +/-12v or +/-15v.
        If that also checks out, you'll want to check voltages on pins 1, 7, 8 and 14 (expecting more or less 0v). Refer to this datasheet:
        https://cdn.badcaps-static.com/pdfs/...d81691050c.pdf
        Assuming that's also all fine, then suspicions move to the amplifier chip itself. Well, unless the potentiometers themselves are still fine. I've encountered a case or two where that turned out to be the case of "no signal".
        • benV
          • Sep 2011
          • 47
          Pins 4 and 11 of the opamp give me - 12,9v and +12,1v
          Pins 1, 7, 8 and 14 give me more or less 0v
          I checked the main volume potentiometer and it's ok too.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Well then, that pretty much only leaves the amplifier chip itself.
            • redwire
              • 3912
              Check resistor R20 may have popped, it looks cracked it might have fused. It is on the second power supply small PCB.
              • benV
                • Sep 2011
                • 47
                First of all "Happy new year" and thanks again for your help
                Redwire. After you talked about the R20 resistor, i opened another pair of speaker and i looked closely the flyback supplys right bottom corners and i found what you can see on pictures sp1flybcksupp.jpg and sp2flybcksupp.jpg. I think that this is the spot where the electric arc happened !
                The R20 resistor on SP1 is definitely blown. Is it enough to kill the board and completely disable the audio output ?
                The auto mode on SP2 doesn't work (the led light stay red) and the board seems to be damaged around R9, R20 and Q3, Q2. Like white powder on the board,
                • benV
                  • Sep 2011
                  • 47
                  I pulled out the R20 resistor but it's ok. My multimeter gives me 10ohms.
                  • redwire
                    • 3912
                    A resistor cracked like that either got stabbed by a screwdriver, or a power surge. I would replace it.
                    I don't know what this little SMPS outputs, maybe 5V. It is not working?
                    I would check the nearby transistor as it is the part that usually fails. In the second picture, the transistor appears installed backwards? I would test Q3 and the diode as well.
                      Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                      by momaka
                      More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                      02-15-2022, 12:43 AM
                    • sli4
                      Original NES power issues
                      by sli4
                      I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                      I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                      Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                      On the big blue connector I get...
                      11-28-2024, 12:52 PM
                      Connect pc speakers to tv without 3.5 jack
                      by nomoresonys
                      Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
                      09-19-2025, 05:17 AM
                    • Widget
                      Logitech R20 speakers - Replacing one of the speakers.
                      by Widget
                      Hi guys,
                      I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                      Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                      Printed on the back of the Logitech speaker is;
                      LOGITECH...
                      05-29-2024, 07:07 AM
                    • EvazX
                      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                      by EvazX
                      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                      However, after some time, the replacement motherboard...
                      08-25-2025, 06:09 PM
