I had a pair of these JBL S412PII speakers for repair last year. Finally got to typing up the post for this, though (warning: long posts ahead, split into 5 parts!)
A little info about the speakers…
These speaker towers have four speaker drivers each: treble, mid-range, mid-bass, and woofer. First three are connected together to the speaker terminals (through a cross-over network for each driver). The woofer, however, has its own amplifier inside the cabinet (often referred to as the “plate amp” online), which receives its signal either from the speaker terminals above or via a single RCA input, labeled “LFE/subwoofer”.
The owner said he bought the speakers brand new way back in the early 2000’s.
They have been in service pretty much 24/7 since then.
Issue/problem appeared after they lost power in the house one day
The problem with the set I got is that one of the speaker towers had its woofer produce garbled and distorted bass. As I suspected, the issue was with the woofer amplifier, which I verified by swapping woofer drivers from the “good” tower to the one with the distorted bass (neither drivers showed distorted bass in the “good” tower.) Furthermore, the distorted bass didn’t quite sound like a blown woofer, as the owner thought. Rather, there was a 120 Hz buzz heard over the driver when it was touched or pushed, confirming an issue with the built-in woofer amp.
Once I opened the amplifier box to take a quick look, it didn’t take much time to notice how darkened the PCB was from heat. I also noted that there was our beloved tan conductive glue on some spots (and fully baked on one). To top it all off, the board was populated exclusively by Su’scon and CapXon 85°C electrolytic caps, some of which darkened by the heat too. Hmmm, what could possibly be wrong with this amp?
It turns out, however, that the caps and glue weren’t the only issues. Closer look later on revealed poor thermal design on the PCB in general (“thermal design”, what’s that?
), along with a few mismatches with the service manual. So for this reason, I am going to split this repair thread into several parts. Feel free to skip to whichever part is of interest to you, as I tend to be a bit long-winded.
For those who have this amp and are looking to get a quick fix for the same issue (without reading this entire thread): just make sure to do the following items.
- Change all electrolytic capacitors - big and small. (In my case, it was one of the big filter caps that had gone completely open-circuit and responsible for the distortion.)
- Remove all tan glue that has turned black/brown (it goes conductive over time!)
- Reflow all solder joints (particularly on all transistors and large parts.)
The items above should take care of the distorted bass and possibly other issues too. In addition to that, it may also help if transistors Q131 and Q134 are heat-sinked (these generate the ±15V rails and run very hot.) For more details on these speakers, read on.
