Tascam us-2x2 blown inputs (noise on signal) help
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I thought I'd ask for some advice from any potential audio gurus out there on this external sound card, mixer thingy, though this is going to be more of a general discussion about faults that can occur on audio equipment of this kind, since it's otherwise a very specific issue on a very specific piece of hardware, so it's unlikely we'll track it down easily.
    The problem is as follows: the chap who brought it in said he damaged it by plugging in the speaker outputs (amplified signal that is) of some tape deck or something to the inputs on the front which normally take a mic or line input. The sound card didn't quite like this apparently since the signal shot into it somehow and damaged something in such way that now I'm getting poor audio quality on both inputs (sounds like sh!t to put it simply) and it gets worse the higher you turn the gain on that channel, plus it peaks out really easily....yeah, good luck figuring out what happened there :|
    When used as an USB sound output it works fine, so the issue is not with the output, but the inputs.
    This is where general discussions may commence: is there a typical "topology" so to say that mixers/consoles/sound devices with line inputs like these typically follow that would allow us to get even close to the area that got busted ? What would be the first thing to check in this case ? Signal DOES come through, but again sounds very distorted. I took it apart, but of course it's all SMD and doesn't show any signs of physical damage. I can post pictures if need be, but to put it very simply, what I noticed was both channels seem to eventually terminate in an op-amp, which I ASSUME operates as an amplifier and then gets sent off to the main IC or whatever. Other than that, there's some TO19 trannies in there and some electrolytics.... The whole circuit looks symmetrical, so it's got a perfectly even number of components and they're all "mirrored", so say two trannies for one channel, another 2 for the other. 2 caps for the first channel, another 2 for the other....you get the idea...should I dive right in and try replacing that op-amp ? What would excessive input drive damage first in an audio device of this kind ? :| Cheers and thanks...I shall return with pics to at least get an idea of what's in there.
    Wattevah...
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Tascam us-2x2 blown inputs (noise on signal) help
    does it have input switching ic chips ?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      No, I believe that's done with the toggle switches on the front: they switch between "LINE/MIC" and "INSTRUMENT". There are no ICs on the "front end" of the machine as far as I can tell, other than that op-amp and the trannies. Also, forgot to mention, it's the 2 input model, not the 4 input one.
      Wattevah...
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        i dont have a schematic so can only guess .
        i might start with looking at data sheet for op amp then checking voltages . if ok maybe get scope out and see where signal starts to go bad .
        • CapLeaker
          Leaking Member
          • 8146
          for me if something blew the input op-amp, that channel was dead as 'dead air'. Did you probe around with the oscilloscope yet?
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Not having a scope OR a schematic indeed makes this mission impossible....might have to scrap the op-amp idea as CapLeaker pointed out...not a whole lot of active components there, unless the sound chip itself got damaged. That is, provided the sound from the input goes THROUGH it and not just straight "out the back" to the outputs, in which case the IC would be OK/irrelevant to the issue.
            Wattevah...
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              It may be that the DAC got damaged. I blew a mike input on a DV9000 many years back because of the same thing. Internal microphones still worked, but one got hissy and distorted, likely the same as you are experiencing now.
              A working TV? How boring!
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Ok, picture time, plus a couple of other things I noticed: the op-amp seems to get hotter than it ought to. I placed my finger on it and I would describe it as hot. Spritzed some isopropyl alcohol on it and it evaporated rather rapidly...
                Second, the "signal" light for the second channel wouldn't go off after I first opened up the thing and put it back together, even with the gain control turned all the way down....if I stick a jack into it, it does go off, but if I plug something into the other end of that jack, such as my laptop or any sound source, it comes back on.
                There's also some buzzing going on: when you first apply power to the thing, the buzzing doesn't come on right away - it fades in gradually, apparently related to that op-amp heating up. The buzzing goes away if I press my finger on it or flex the board slightly, which is also strange. I can't pinpoint what's causing it. If I turn the gain up about half way, I get all sorts of crackling and popping like "phaser" sort-of noises...I didn't bother to record them since you get the idea - NOT GOOD
                Wattevah...
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Opamp should not get hot. Replace that first and see how it goes.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Well what do you know ? Replacing the op-amp seems to have solved the issue To my shame, I don't have two 5mm to 3.5mm adapter jacks to properly test it, so I used my only one to feed in the signal from the laptop and then used a mono jack adapter on the headphone socket to at least get a general idea, but the distortion seems to have disappeared and I can now turn up the gain all the way up without it peaking (with nothing plugged in, of course) Cheers guys
                    Wattevah...
                    • AstutePauciloquent
                      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                      by AstutePauciloquent
                      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                      11-23-2023, 11:02 PM
                    • tony359
                      by tony359
                      11-28-2023, 05:18 AM
                    • howardc64
                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                      by howardc64
                      Failure Symptom
                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                      Where is the short?
                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                      05-27-2025, 02:56 PM
                    • MegaZAC
                      Onkyo TX-SR805 noise in one channel
                      by MegaZAC
                      Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                      Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                      There's some logic behind it. As soon as I select an input I get only left...
                      04-23-2025, 10:09 PM
                    • JayPoorJay
                      Converting +/- 5v to a Usable Hz Signal
                      by JayPoorJay
                      Good morning.
                      I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                      This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                      The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                      08-07-2022, 08:35 AM
