Yamaha RXV595 turns off instantly
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi guys, a friend brought me a Yamaha RXV595 that turns off after 3 seconds, eventually it stays turned on for longer time but if the input selector knob is turned either way it shuts off instantly.
    Since i never repaired a audio equipment before, i hope someone might help on this issue.
    I downloaded the service manual and this is what i get when it boots into service mode:
    DVD/LD MAIN BYPAS
    DVD/LD DC 18% ( <---- what does this message mean)
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Yamaha RXV595 turns off instantly
    press effect + program + standby/on buttons all at once.
    Follow the white rabbit.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Hey Goon, i tried what you mentioned. It says EFFECTS OFF and turns off after 3 seconds. Still turns off instantly after being turned on again and again
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ Huh. This one must use a different button combo to display errors...
        Here's a good question. European version (240v powered) or US (110v). The 240v version is flawed across many models.
        EDIT: i'll throw this out there for anybody finding this thread later on. The "Green" cap (metalized film) fim fails. The topic is well covered. https://www.youtube.com/watch?v=MwvjAtSr5t8 https://www.youtube.com/watch?v=h0j7QjriD9o
        • 6ot4hr
          • Oct 2014
          • 87
          • Croatia
          European, 240V
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            ^ Ok. barring retrieving any error codes, i would try that capacitor. What happens when that cap fails is the 5v rail goes low. 3 seconds to dead is a fault it will cause. Eventually it will get to the point of being dead totaly. C405 i believe.
            • rievax_60
              • May 2012
              • 897
              • australia
              Shutdown after 3 sec is likely to be excessive amplifier DC offset. Sometimes it can be a fault in the protection circuitry.
              Measure the DC offsets.
              • rievax_60
                • May 2012
                • 897
                • australia
                Also measure the voltage at the Base of one of the mute transistors to see if it ever attempts to go negative just before shutdown. It should go to -15v in a properly working receiver.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  Correct me if im wrong, but wouldn't it display something along the lines of "PROTECT" or "SPEAKER FAULT" If it was the outputs? Or am i giving this computerized junk too much credit?
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    It does say "DC 18%", I'm hoping that this might mean DC protect.
                    I have seen false DC protect shutdowns caused by leaky diodes causing unindented interaction between Mute, I protect and DC protect circuitry.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      ^ Huh. yeah, that could be a protect. 18% of what though? Im going to try and find a service manual for this. The CR series is easy to get documentation on, why not RX series
                      Mid/Late 90s Pioneer stuff has a habit of transistors going leaky in the protest circuit and intermittently cutting in, so bad SS parts wouldn't surprise me.
                      Found the diag mode. https://www.manualslib.com/manual/70...page=10#manual
                      Using the front panel keys of the main unit.Plug in the AC power cord , and, with Power OFF, hold down the "INPUT MODE" and "FM/AM" keys simultaneously(Step 1), and then press the "STANDBY/ON" key (Step 2)
                      Well shit, look at that.
                      DC % Appears when the power amp DC protection function has been activated. For the % value, the voltage at that point is shown by 5V/100%. When power is turned on in an abnormal status, power will turn off after two seconds
                      This computerized stuff is weird. And i guess i can't read well enough to realize OP already has it in service mode... Christ im batting 0s today. Im out before i make myself look more clueless.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I would measure for short on the finals. Just to be sure.
                        • 6ot4hr
                          • Oct 2014
                          • 87
                          • Croatia
                          Quick update, i checked all the voltages on and from the regulators and they seem okay... Interesting thing is this:
                          It shuts off instantly if the impedance switch is set to 8 Ohms
                          It only works on one speaker on channel A on 4 Ohm impedance setting, if anything else is connected to output it shuts down instantly
                          If the volume is turned beyond 60% it shuts down on channel A
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            ^ Yeah, follow rievax_60s advice and Measure the DC offsets.
                            • R_J
                              • Jun 2012
                              • 9535
                              Like suggested above... Check the offset voltage on each channel, It can be measured at the center pin of R692,R696, R694, R690 & R688. It should be close to zero volts. which ever channel is not zero, that channel has a problem.
                              • 6ot4hr
                                • Oct 2014
                                • 87
                                • Croatia
                                Thanks Guys,
                                Here are the voltages:
                                R692 = -11mV
                                R696 = -8mV
                                R694 = -14mB
                                R690 = 4mV
                                R688 = +32V
                                That R688 doesn't seem to be remotely in the range, any suggestions?
                                • R_J
                                  • Jun 2012
                                  • 9535
                                  well there's your problem channel, main Left. start by checking the transistors in that output circuit, check the R688 and see if one of the two resistors are open, Also check R598 & R602 & R599. see how those parts check out, if they seem ok (I doubt it) check Q506, Q511, Q512
                                  • 6ot4hr
                                    • Oct 2014
                                    • 87
                                    • Croatia
                                    Hi guys, R J i did some testing, i think q506 might be the problem.
                                    Resistors measured:
                                    R688 0.18 / 0.20 Ohm
                                    R598 5 Ohm
                                    R599 340 Ohm
                                    R602 5 Ohm
                                    Q511 and Q512 seem okay, but take a look at the Q506 vs Q507 and Q509. Q506, Q507 and Q509 should have a same role, but Q506's B and Uf are both 0.
                                    I did not measure voltages at the Q's, will do that and report soon
                                    • R_J
                                      • Jun 2012
                                      • 9535
                                      I don't use one of those, I use a meter with diode test. I guess Q506 could be bad, that amp is dc coupled so that could cause the offset voltage to be that way
                                      • Zilicon
                                        AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                                        by Zilicon
                                        Hearty greetings to everyone, trust you all are doing excellently well.
                                        Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                                        The power stables in very rare case. Once it was stabled, everything works fine.
                                        Once the power switched is pressed, 5V and 3V were present.
                                        The things i have done:
                                        1. I have check for shorts on the board, but nothing. The board is short free
                                        2. Not a power switch problem, it behaves the same without the switch ...
                                        06-10-2024, 05:05 AM
                                      • Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                        by Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                        03-15-2024, 09:37 AM
                                      • nzphil
                                        Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                                        by nzphil
                                        I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                                        04-11-2021, 05:58 PM
                                      • www
                                        LG L192WS-BN backlight turns off after 1 second
                                        by www
                                        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                        03-24-2024, 05:26 PM
                                      • reessi
                                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                        by reessi
                                        Hello:
                                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                        I started on the ACER:
                                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                        10-29-2024, 11:31 AM
